Edimax 1Port USB GDI Combo Print Server
Quicklinx: 5BR3WS00 Mfr#: PS-1216U
This combo print server allows you to share your GDI printer to all PCs through the network. GDI printers, run in Windows Graphical Device Interface (GDI) protocol. Sometimes GDI printers are called host-based printers because they rely on the host computer (Win2000/XP/Vista) to rasterize pages to an image format, not PostScript or PCL language. Therefore, almost none of Print Servers in the market can support GDI printers. PS-1216U implements a special technology which allows it to communicate with the GDI printer as if it is connected directly to your computer. With the feature, the GDI printer becomes a shared device easily.
  • Shares your GDI/host-based printers
  • Easy installation and configuration (with Web-based configuration) and fault tolerant upgrades
    PS-1216 easy-to-use Windows installation wizard allows quick installation and setup. The print server can also be conveniently configured from any network client with a web-browser. Users don't have to worry about errors occurring in the midst of an upgrade, thus preventing the print server from operating. The print server's fault-tolerant upgrade function resumes the upgrade should problems occur during the initial upgrade.
Edimax PS-1216U - print server - USB 2.0 - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet
5.8 cm x 7.5 cm x 2 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP
RAM
2 MB
BenQ CM 3000; Canon FAXPHONE L120; ImageCLASS MPC 190; PIXMA MP530; Epson EPL 6200L; HP Color LaserJet CP1215; LaserJet 1000, 1020, 1022, M1120, P1006, P1505, P2015; Lexmark P6250, X2350, X3350, X3470, X5470, X6170, X7170, X7350, Z603, Z617, Z645, Z735
Print server
External
USB 2.0
Ports
10/100 Ethernet
Wired
Cabling Type
Ethernet, Fast Ethernet
TCP/IP
DHCP support, auto-uplink (auto MDI/MDI-X)
Processor / Memory
RAM
2 MB
Flash Memory
512 KB
1 x 100Base-TX - RJ-45
1 x USB 2.0 - 4 pin USB Type A
C-Tick, FCC
Power adapter - external
5.8 cm
7.5 cm
2 cm
55 °C
10 - 90%
BenQ CM 3000 , Canon FAXPHONE L120 , Canon ImageCLASS MPC 190 , Canon PIXMA MP530 , Epson EPL 6200L , HP Color LaserJet CP1215 , HP LaserJet 1000, 1020, 1022, M1120 MFP, P1006, P1505, P2015 , Lexmark P6250, X2350, X3350, X3470, X5470, X5470 Business Edition, X6170, X7170, X7170 Business Edition, X7350, X7350 Business Edition, Z603 Color Jetprinter, Z617, Z645, Z735
