Eaton 3S 700VA IEC sockets
Quicklinx: 7H2FWS00 Mfr#: 3S700IEC
The Eaton 3S offers affordable and reliable UPS protection against the most common power quality problems such as lightning strikes, storms, accidents etc… With its 8 outlets and its battery, the unit provides sufficient battery backup time to last through most power outages. The shutdown software makes it possible to automatically save your work and shut down your application without losing any data. for office and home computers. The attractive design and glossy finish of the Eaton 3S fits easily into modern office environment either under your desk or mounted on a wall. Ideal for protecting computers and peripherals, broadband modems, IP telephony equipment and point of sale equipment.
Eaton 3S - UPS - 420 Watt - 700 VA
UPS - external
3.8 kg
Input Voltage
AC 161-284 V
Output Voltage
AC 220/230/240 V ± 7%
Power Capacity
420 Watt / 700 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
3 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Run Time (Up To)
2 min at full load
USB
Apple MacOS, Linux, Microsoft Windows Vista / XP / 7
17 cm x 33.5 cm x 8.6 cm
UPS - external
Input Voltage
AC 161-284 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 7% - 50/60 Hz
Max Electric Current
10 A
Power Capacity
420 Watt / 700 VA
Dataline Surge Protection
Network/phone line - RJ-45 - 1 input line / 1 output line
Surge Suppression
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
2 min at full load , 9 min at half load , 6 min at 70% load
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable - external , USB cable - external
LED indicators, deep discharge protection, cold-start function
IEC 62040-1-1, IEC 62040-2
Limited warranty - replacement - 2 years , Limited warranty - replacement - batteries - 2 years
17 cm
33.5 cm
8.6 cm
3.8 kg
