Dynamode Cat5e Network RJ45 Patch Panel 24 Port 1U 19"
Quicklinx: 8L4MWS00 Mfr#: PPAN-24-LC2
This LMS Data 24-Port CAT5e Patch Panel is a 1U, 19 inch rack mount unit that is pre-loaded with CAT5e modules and is typicallly used to terminate the CAT5e cabling for an office at the server room within a Data Cabinet. Markings are provided on the back for both 'A' and 'B' style wiring configurations, and a write-on area is provided on the front, adjacent to each of the ports, for labelling purposes. Compatible with both 110 and Krone punch down tools.
Key Features -Rack mount 19" form factor with 1U height
-Suitable for CAT5 and CAT5e UTP Ethernet cables
-Quality pressed Steel construction with individual port labelling
-Gold over Nickel plated jack contacts.
-Phosphor Bronze & Nickel plated IDC terminals.
-IDC terminals accept 22 to 26AWG solid and stranded wires
-Rear mount IDC connection block, KRONE compatible
-Horizontal Punch Down
