Dynamode Card Reader
Quicklinx: 7SDPWS00 Mfr#: USB-ALL-INT
Front-side Memory & USB connection.
Introducing the latest internal 3.5" Drive Bay multifunction Memory Card reader with integral USB2.0 Port - the Dynamode USB-ALL-INT Offering the flexibility of a full-time Memory Card Reader for Desktop and Server Computers, the USB-ALL-INT reads the latest Card Formats courtesy of its 5-slot Card Reader, including the popular CompactFlash I/II, SD/MMC, MemoryStick®/DUO, xD® and T-Flash. Also featured in this latest model is a single USB2.0 480Mbps Port for easy connection to Joysticks, Mice, Scanners and Cameras.
With easy internal connection to your existing Motherboard and full compliance with a variety of Operation Systems including Microsoft™ Windows XP and Vista®, the USB-ALL-INT is your ideal upgrade solution.
  • Internal 3.5" housing for Desktop PCs
  • 5-Slot Memory Card Reader - Plug n' Play
  • Fast Memory Read/Writes ~ up to 480Mbps
  • Supports CFI/II, SD, MS/MS DUO, xD, MMC
  • Supports T-Flash Memory Card Support
  • Built-in USB2.0 Port for `front-side' connectivity
  • Microsoft Windows® 98/SE/ME/2000/XP/Vista®
Dynamode USB-ALL-INT - card reader - USB 2.0
Card reader - internal - 52 in 1
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Microdrive, SD Memory Card, Memory Stick Duo, xD-Picture Card
Host Interface
USB 2.0
Required Bay
3.5" internal
Host Interface
USB 2.0
Required Bay
3.5" internal
Memory Card
(max)
Required Ports
1 x 4 pin USB Type A
Apple MacOS 8.6 or later, Microsoft Windows 98/ME/2000/XP
USB cable
