Dynamode 9U 450mm 19" Data / Comms / Rack Wall Cabinet w/ Shelf
Quicklinx: 8L2QWS00 Mfr#: CAB-W9U-EL450
Designed to exacting standards, the Dynamode 19" 9U Wallmount Cabinet offers a compact and secure containment system for your Rackmount active and passive devices including Switches, branch Routers, Telcom and low density cable patching. Ideal for both Private and Public Sector installations whereby the enclosure can be fixed in secure locations. Flexible in design and features many design features found on the larger Enclosures such as front U numbering, multiple cable entry points and left/right hand Glass door location, the Dynamode 19" 9U Wallmount Cabinet also features a single, vented shelf for non Rack mountable devices such as Modems, Access points and branch Routers.
Key Features: -Ideal Wall Mounted Enclosures for Home, SME and restrictive workspace
-9U (H460mm x W550mm x D450mm)
-If required, can be placed on desk or on the floor
-Standard 19" vertical profiles with a choice of depths
-Ideal for low density Network Switches, Patch Panels, CCTV and Telco systems
-Passive ventilation slots with the option of Rackmount Fan Trays
-Easy to install, can be afixed to most Wall types
-Useful design features including front U numbering, top and bottom cable entry
-Bundled FREE Vented Shelf for non rack mount devices
-Front lockable door with left/right fixing for total flexibility
-Assembled in the UK
Offering excellent quality coupled with value for money, the new Dynamode Data EcoNetCab Wall Mountable Telecom and Data Enclosures are ideal for smaller Networking, SME and branch offices.
