Dynamode Extra 2.5in or 3.5in Hot Swap Hard Drive Tray for SATSASBAY3BK
Customer rating: 4.0* (Write a review)
Quicklinx: 48P3WS00 Mfr#: USB-HD2.5
  • Compliant with USB2.0 (480 Mbps) and USB1.1 Standards.
  • For use with 2.5" IDE Hard Disk Drives - 80 Gb Max.
  • Transfer rates of 480 Mbps/12Mbps
  • Supports Windows ME/2000/XP/VISTA and MAC OS 8.6 or higher
  • Hot Plug and Play feature
  • Dimensions: 125 x 75x 12mm
Dynamode USB-HD2.5 - storage enclosure - ATA - USB 2.0
Storage enclosure - external
Bus Type
USB 2.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
ATA
Supported Devices
Hard drive
Microsoft Windows 98 Second Edition, Apple MacOS 8.6 or later, Microsoft Windows 98/ME/2000/XP
2.5"
Host Bus
USB 2.0
Storage Controller
ATA
Supported Devices
Hard drive
No CPU
Bays
1 x internal - 2.5"
1 x ATA
1 x USB 2.0
-40 °C
65 °C
8 - 90%
Customer reviews
Write a review for the Dynamode Extra 2.5in or 3.5in Hot Swap Hard Drive Tray for SATSASBAY3BK here!
It is only for the less than 80GB drives
Reviewed by Anonymous Review Posted 13/08/2008
Enclosure is OK, but could be used only for the drives with less than 80GB capacity - it would be helpful, if this info will be added to the description section.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Works well, comes with cable, excellent value
Reviewed by Joe. Review Posted 02/08/2008
Had it working within a couple of minutes (WinXP)literally plug and play.
  • Overall 5*
  • Ease of use 5*
Super Duper
Reviewed by Degsy. Review Posted 10/07/2008
I have to say, when I opened the box I was gutted! I was hoping for the SATA version, but then after checking my order, it was my own fault for ordering IDE.
No matter, I have a 2.5" IDE drive to play with, so hooked it together and plugged into my PC.
To be honest for the price I wasn't expecting much, but I have to say i was pleasantly surpised.
Flawless.
Hmm, now to buy another one for SATA!!! :)
  • Overall 5*
  • Ease of use 5*
Read all 12 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
