Small Is the New Big: The world's smallest, most advanced storage array
It's a Drobo, so by definition it's easy-to-use. Now it's also the fastest portable storage array, with cutting-edge Thunderbolt and USB 3.0 connectivity and innovative use of solid state drives (SSDs).
Whether you're working at your desktop, shooting and editing photos or videos onsite, or traveling to the next location, it's the world's first high-performance and protected portable storage array. So now you can take and access your valuable digital assets wherever you go.
Amazingly Mini
Drobo Mini has everything that's in the high capacity Drobo 5D in a package that's the size of a deli sandwich. Made of a cutting-edge metallic carbon fiber with a soft-touch rubberized finish, Drobo Mini is small, rugged, and feels as cool as it looks. From the modern materials to the wraparound light indicators to the drive bay design, Mini is truly big storage in a small box.
Weighing in at 3 pounds fully loaded with drives, you can now carry up to 3TB 1 of usable and protected capacity in your travel bag. To make Drobo Mini as portable as possible, there's an optional carrying case.
Data Protection and Expandability Made Simple
Built on award-winning BeyondRAID™ technology with single- or dual-drive redundancy, Drobo Mini protects your data without any user interaction, even in the event of multiple drive failures. Drives can be added or hot-swapped on-the-fly for storage expansion with zero downtime. If you're running low on space, the wraparound lights on the front tell you what to do. Just add a drive in an empty bay or remove a smaller drive and replace it with a larger one.
Power of Thunderbolt and Flexibility of USB
Thunderbolt I/O technology provides performance that no personal storage has been able to achieve, especially one that's portable. This allows you to move large amounts of data in a fraction of the time it used to take. Drobo Mini is equipped with dual Thunderbolt ports for daisy chaining. Connect up to six Thunderbolt devices and/or a non-Thunderbolt monitor at the end of the chain. This allows even the most portable laptop computers access to high-performance storage while retaining connectivity to other devices and an external monitor.
Drobo is the only storage array that offers Thunderbolt and USB 3.0. This latest USB also offers high-performance connectivity and is backward compatibility with computers running compatible versions of Mac OS X or Windows.
Capacity AND Performance
Data-Aware Tiering technology, usually reserved for business-class storage solutions, is also available in this portable Drobo. It intelligently uses the high-performance flash in SSDs to accelerate performance of the storage array, allowing applications such as Adobe Premiere and Apple Aperture fast access to data.
To keep capacity of the Drobo at a maximum, the Drobo Accelerator Bay accepts an industry-standard mSATA SSD, leaving all four 2.5" drives bays available for highcapacity HDDs.
Power Protecting Your Critical Data
Drobo doesn't just protect you from a drive failure, but also from potential data loss after a power outage. Drobo Mini includes a battery that protects all data in memory, or cache, that is, data on its way to the drives.
When power spontaneously goes away, the battery keeps the Drobo alive long enough for the data to be written to nonvolatile storage. The battery recharges itself and is designed to last for the life of the product.
First Drobo with 2.5" Drives
Drobo Mini takes 2.5" drives--that's what makes it portable. Four hotswappable drive bays support drives of any capacity. No carriers or screws are needed to insert drives into a Drobo and the Drobo Mini is no different. An innovative new design allows drives to click in and out like a ballpoint pen. Since 2.5" drives are primarily used in laptop computers, they're designed to be portable. Because of this, you can pick up and move Drobo Mini around with confidence.
Amazingly Mini
Drobo Mini has everything that's in the high-capacity Drobo 5D in a package that's the size of a deli sandwich. Made of a cutting-edge metallic carbon fiber with a soft-touch rubberized finish, Drobo Mini is small, rugged, and feels as cool as it looks. From the modern materials to the wraparound light indicators to the drive bay design, Mini is truly big storage in a small box. -
First Drobo with 2.5" drives
Drobo Mini takes 2.5" drives - that's what makes it portable. Four hot-swappable drive bays support drives of any capacity. No carriers or screws are needed to insert drives into a Drobo and the Drobo Mini is no different. An innovative design allows drives to click in and out like a ballpoint pen. -
Data protection and expandability made simple
Built on award-winning BeyondRAID technology with single- or dual-drive redundancy, Drobo Mini protects your data without any user interaction, even in the event of multiple drive failures. Drives can be added or hot-swapped on-the-fly for storage expansion with zero downtime. If you're running low on space, the wraparound lights on the front tell you what to do. Just add a drive in an empty bay or remove a smaller drive and replace it with a larger one. -
Power of thunderbolt & flexibility of USB
Thunderbolt I/O technology provides performance that no personal storage has been able to achieve, especially one that's portable. This allows you to move large amounts of data in a fraction of the time it used to take. Visit the Thunderbolt technology site to learn more about this exciting way to connect devices.
- Drobo Storage for Professionals Drobo Mini - hard drive array
- Hard drive array
- Total Array Capacity
- 0 GB
- Interface
- USB 3.0, Thunderbolt
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- Supported Drives
- SATA-600
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 0 HDD - hot-swap
- OS Required
- Microsoft Windows 7 (32/64 bits) SP1, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- Power
- AC 120/230 V - 50/60 Hz
- 18.72 cm x 18 cm x 4.46 cm
- 998 g
- 2-year warranty
- Hard drive array
Chassis
- 0
- Supported Devices / Modules Qty
- 4
- Supported Drives
- SATA-600
Storage
- 0 GB
- HDD Array External Interface
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap - 2.5"
- 1 x USB 3.0 , 2 x Thunderbolt
- OS Required
- Cables Included
- 1 x USB 3.0 cable - 1 m , 1 x Thunderbolt cable - 1 m
- Software Included
- Drivers & Utilities
- Power Device
- External power adapter
- Voltage Required
- 18.72 cm
- 18 cm
- 4.46 cm
- 998 g
- Limited warranty - 2 years
