Remote working has made smartphones increasingly popular. In public places, it is difficult to protect the data on the display from being seen by third parties. DICOTA has the perfect solution for you! The Secret 4-Way is a highly effective protective film for your display that protects personal and confidential data from prying eyes. The film adheres directly to the full surface of your display thanks to the use of a silicone layer.
The Secret 4-Way protective film not only prevents unwanted viewing of your display, but also protects against scratches. Additional product features include high mechanical resilience and ease of removal. The 4-way technology protects the display from being viewed by prying eyes from all four sides: left/right and top/bottom. A handy and effective way to ensure that no one but you can see your data. Ideal for use in a hotel or on the bus, train or plane.
- Blue light cutting
- Touch capable
- Reduces reflections and fingerprints
- A clear view at all times and accurate colour reproduction
- High scratch resistance
- Attaches easily without forming bubbles
- No residue when removed
- Silicone layer on the back allows for full-surface adhesion
- DICOTA - screen protector for mobile phone
- Product Type
- Screen protector - with privacy filter - 4-way
- Intended For
- Mobile phone
- Installation Type
- Adhesive
- Protection
- Scratch-resistant, fingerprint-proof
- Product Material
- PET
- 6.458 cm 13.979 cm
- Thickness
- 0.42 mm
- 10 g
- Black
- 2-year warranty
- Designed For
- Apple iPhone 12, 12 Pro
- Product Type
- Privacy Protection
- 4-way
- Intended For
- Mobile phone
- Installation Type
- Adhesive
- Protection
- Product Material
- PET
- 6.458 cm
- 13.979 cm
- 10 g
- Thickness
- 0.42 mm
- Black
- 2-year warranty
- Designed For
