Faster and more versatile than ever before, the Devolo 9238 dLAN 650 Triple+ AV2 600 HomePlug starter kit helps expand your home network in any room you choose. Using the existing electrical wiring in your home, you can now connect up to three devices that are located away from your router at speeds up to 600 Mbps. This Devolo 9242 dLAN 650 Triple+ AV2 600 HomePlug starter kit includes everything you need to get started or upgrade an existing Devolo HomePlug setup.
Complete HomePlug starter kit, includes everything you need to get started
The fastest connection at up to 600 Mbps using the AV2 HomePlug standard
Even higher performance and longer range with the latest technology
Connect three (3) devices using the integrated Gigabit LAN ports
The integrated socket ensures that no electrical outlet is lost
The easy way to connect using your home's power lines
Includes dLAN Cockpit software for home network configuration
Automatic encryption! Active protection against unauthorised access
Optimal Internet connection for computers, televisions and game consoles
Compatible with all adapters of the 200/500/650 Mbps product series
Pass-Through Electrical Socket
Featuring a pass-through socket, both of the Devolo dLAN 650 AV2 600 HomePlug adapters in this starter kit can alleviate any lost of a socket by simply allowing another device to be plug directly into the HomePlug.
3 x Gigabit LAN Ports
With a -port Gigabit LAN connection, you can connect an Internet-compatible device (e.g. game console, television or media receiver) to the Internet at any time via an Ethernet network cable directly to the HomePlug in this kit.
Standard Warranty: 3-Years
- devolo dLAN 650 triple+ - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit - 3-port switch (integrated)
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 600 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, HomePlug AV
- Power
- AC 230V (50 Hz)
- 7.2 cm x 4.1 cm x 14.3 cm
- System Requirements
- Apple MacOS X 10.6, Ubuntu, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Ubuntu (64-bit), Apple OS X 10.9 Mavericks
- Localisation
- English / United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 600 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- 1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 5.2 Watt
- Cables Included
- 1 x network cable
- Localisation
- Software Included
- Drivers & Utilities
- OS Required
- 7.2 cm
- 4.1 cm
- 14.3 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
