Today, the Internet is everywhere: computers, game consoles and consumer electronics devices need a fast and stable Internet connection for work, information and entertainment.
dLAN from devolo is the ideal solution: as fast and easy as a cable network, as flexible as WLAN. The secure networking via the power line makes every power outlet an Internet access point. Now, you can connect even as many as three network-compatible devices to the dLAN 500 AVtriple+, making it ideal for the living room and home offi ce.
The integrated socket ensures that no electrical outlet goes to waste. Setting it up could not be easier - just plug it in, connect the devices, and you're done.
dLAN® 500 - triple the networking performance.
Powerline adapter for connecting up to 3 network-compatible devices
Simple and secure: functions in every room, in every building
Product description
Start your home network with the dLAN® 500 AVtriple+ from devolo. You can connect up to three computers or network-compatible IT devices to this dLAN® adapter. This provides the ideal connection for PC, printer and NAS hard drive, for example. dLAN® 500 provides a transmission rate of 500 Mbps. Automatic data prioritisation ensures that there is no WLAN stutter--all devices are connected with the highest quality. The automatic 128-bit encryption offers maximum security. Moreover, with the integrated electrical socket, the dLAN® 500 AVtriple+ ensures that no power outlet goes to waste, while an integrated mains filter ensures maximum dLAN® performance.
- devolo dLAN 500 AVtriple+ - powerline adapter - wall-pluggable
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
- Power
- AC 230V (50/60 Hz) 100 mA
- 7.2 cm x 4.2 cm x 14.3 cm
- 248 g
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Powerline adapter
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, EN55022, EN 60950-1, EN 50412
- Status Indicators
- Power, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
- 1 x HomePlug AV - power , 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- Electric Current Required
- 100 mA
- 6 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 7.2 cm
- 4.2 cm
- 14.3 cm
- 248 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
