Make use of the home network of the future today, and connect computers and consumer electronics via the household power line-with the dLAN 500 AVplus! All devices can be connected to each other and the Internet quickly, easily and securely. dLAN reaches speeds of up to 500 Mbps and features even higher performance than network cables or WLAN-and that without WLAN picture stutter or the need to route cables. And with its integrated electrical socket, no power outlet goes to waste.
- Devolo dLAN 500 AVplus Network Kit - bridge - wall-pluggable
- Packaged Quantity
- 3 (specifications are for single item)
- Bridge
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
- Power
- AC 230V ( 50/60 Hz )
- 6.6 cm x 4.2 cm x 13 cm
- 240 g
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista (64-bit versions)
- Localisation
- United Kingdom
- 3 years warranty
- Packaged Quantity
- Bridge
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Link activity, power
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM , 1024 QAM, 4096 QAM
- 1 x HomePlug AV - power , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Power supply - internal
- Voltage Required
- 6 Watt
- 6.6 cm
- 4.2 cm
- 13 cm
- 240 g
- Cables Included
- Network cable
- EN 60950, EN55022, EN 50412
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
