The fastest high-speed home network - digital HD entertainment and 3D transmission throughout the home.
- High transfer rate of up to 500 Mbps
- For all types of bandwidth-intensive transmission
- Transmits multiple HDTV streams and even 3D movies reliably throughout the home
- Full compatibility with all 200AV HomePlug AV adapters
- Best energy saving mode: consumption is only 0.5 watts in standby mode
- 3 year manufacturer's warranty, as unit is designed, tested and certified in Germany
HD entertainment and fast home network in one: with speeds of 500 Mbps, the devolo dLAN® 500 AV mini is powerful enough to transmit even 3D movies to every room of your home. Without routing cables or WLAN picture stutter - simply over the electrical wiring. Connect computers, laptops, game consoles as well as Internet TVs and hard drive recorders to each other and to the Internet. The first powerline adapter of the latest generation is fully compatible with all 200 AV adapters, is extremely energy saving and, thanks to its flat, inconspicuous design, can be positioned anywhere.
Networked home entertainment in 3D
The trend towards elaborate 3D blockbusters in HD resolution is unbroken in European living rooms. With dLAN 500, devolo supplies the ideal solution for the increased demands for a multi-room compatible entertainment network that can handle the bandwidth of high-resolution cinematic adventures in 3D. dLAN 500 is based on the international IEEE 1901 standard and thus is compatible to all corresponding standardized powerline adapters and the previous dLAN 200 generation. Moreover, dLAN 500 offers complete TR069 support for comprehensive remote management. This allows firmware to be installed by the Internet service provider in remote maintenance or the entire product scenario to be configured automatically. -
High energy efficiency to the EuP standard
However, devolo designs its products not only for high performance, but also for energy efficiency. Advances in Dynamic PowerSave technology have made it possible to reduce energy consumption to less than 0.5 watts in standby mode. Thus even today, the dLAN 500 adapters comply with the EuP standard for 2013. This directive, passed by the European Union, stipulates both environmentally responsible energy efficiency and the general environmental compatibility of electrical devices. -
DVB-S2 via dLAN - satellite TV in HD quality from the power outlet
Not only can dLAN be used as an IP triple play network, with dLAN TV Sat, devolo is offering a smart solution for transmitting digital satellite TV in HD quality via the household electrical wiring. Moreover, the DVB-S2 and Quality of Service performance features ensure that the TV signal from the satellite to the power outlet reaches the receiver in the highest quality. To make this possible, devolo has developed a dLAN tuner that is connected directly to the LNB receiver of the satellite system. Once activated, it provides satellite TV through each power outlet in the home. Reception is also possible via the dLAN TV Sat 1300-HD digital satellite receiver. It serves simultaneously as an EPG-supported video recorder. Consumers can use USB mass storage devices such as hard drives or memory sticks as storage media. In addition, a timeshift function is integrated which allows users to pause the current TV program. -
dLAN USB extender - USB devices in the home network
devolo is presenting industry visitors to the CeBIT fair with the dLAN 200 AV USB extender, a type of dLAN USB adapter that connects devices such as USB printers and USB hard drives to the computers in the home easily via the mains supply. The innovative powerline product makes every USB hard drive and USB printer a network device that can be shared by multiple users without having to be connected locally. Thus the dLAN USB extender not only enables shared use, but also provides outstanding flexibility for positioning printers and hard drives anywhere in the home. -
dLAN Cockpit - home network management made easy
With dLAN Cockpit, devolo is featuring a generation of its dLAN management software. All previously available programs are now brought together into a single appealing interface -with significantly expanded functions. With its innovative network display, the program shows the connection speed of all adapters in the dLAN. A dLAN optimization wizard analyzes the home network and provides tips on how to further improve the transfer rate. Simultaneously, the dLAN Cockpit is also used to configure all security settings, like the adapter's encryption. When dLAN pioneer devolo provides an update to help its adapters perform better, this update can now be carried out directly in the network. In addition to customized configuration of an individual adapter, network-wide configuration is also possible, such as simultaneous installation of firmware upgrades on all dLAN devices.
- devolo dLAN 500 AVmini Network Kit - Network Kit - powerline adapter kit - desktop
- Powerline adapter kit
- Packaged Quantity
- 3 (specifications are for single item)
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901
- Power
- AC 120/230 V (50/60 Hz)
- 6.6 cm x 2.9 cm x 8 cm
- 103 g
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista / XP / 7, Microsoft Windows Vista (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV, IEEE 1901, EN 60950, EN55022, EN 50412
- Status Indicators
- Power, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, OFDM, 1024 QAM, 4096 QAM
- LAN: 1 x HomePlug AV - power , LAN: 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Voltage Required
- 5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 6.6 cm
- 2.9 cm
- 8 cm
- 103 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
