Devolo dLAN® 500 WiFi Network Kit
Quicklinx: 8NWVWS00 Mfr#: 9092
  • IEEE 802.11n
Wi-Fi, wherever you want it
The perfect combination: dLAN® powerline technology and Wi-Fi
Finally, full-strength reception for smartphones and tablets Including one-of-a-kind WiFi Move Technology Integrated fast Ethernet connection Compact and unobtrusive design
dLAN® 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection. As a Powerline adapter, the dLAN® 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room.
The integrated wireless LAN also provides complete Internet coverage to every nook and cranny. Smartphones, tablets and laptops have full-strength coverage right from the start without any problems.
An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection.
Intelligent WiFi Move Technology provides even more freedom: Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place. The dLAN® 500 WiFi from devolo brings the future to your home.
devolo dLAN 500 WiFi Network Kit - Network Kit - powerline adapter kit - Wi-Fi - wall-pluggable
Powerline adapter kit
Packaged Quantity
3 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
AC 230V (50 Hz)
6.8 cm x 4.1 cm x 6.8 cm
Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3-year warranty
Packaged Quantity
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Max Range Open Space
300 m
CSMA/CA
Encryption Algorithm
WPA, WPA2, 128-bit AES, WEP
Status Indicators
WLAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV , Antenna: 1 x
Internal power supply
AC 230V (50 Hz)
5 Watt
1 x network cable
United Kingdom
6.8 cm
4.1 cm
6.8 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
