Wi-Fi, wherever you want it
The perfect combination: dLAN® powerline technology and Wi-Fi
Finally, full-strength reception for smartphones and tablets Including one-of-a-kind WiFi Move Technology Integrated fast Ethernet connection Compact and unobtrusive design
dLAN® 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection. As a Powerline adapter, the dLAN® 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room.
The integrated wireless LAN also provides complete Internet coverage to every nook and cranny. Smartphones, tablets and laptops have full-strength coverage right from the start without any problems.
An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection.
Intelligent WiFi Move Technology provides even more freedom: Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place. The dLAN® 500 WiFi from devolo brings the future to your home.
- devolo dLAN 500 WiFi Network Kit - Network Kit - powerline adapter kit - Wi-Fi - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 3 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
- Power
- AC 230V (50 Hz)
- 6.8 cm x 4.1 cm x 6.8 cm
- System Requirements
- Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 500 Mbps
- Max Range Open Space
- 300 m
- CSMA/CA
- Encryption Algorithm
- WPA, WPA2, 128-bit AES, WEP
- Status Indicators
- WLAN, link/activity
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, 1024 QAM, 4096 QAM
- LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV , Antenna: 1 x
- Power Device
- Internal power supply
- Voltage Required
- AC 230V (50 Hz)
- 5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 6.8 cm
- 4.1 cm
- 6.8 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
