Your home network from the power outlet. Unpack. Plug it in. Get started. The easy way to connect using your home's power lines. Turn any power outlet into an Internet access point.
High-speed data transmission at powerline speeds up to 500 Mbps with two Fast Ethernet connections for connecting additional devices.
Compact design for convenient placement throughout the home, at any power outlet. Ready to use immediately. Without any cables, and without any technical installation whatsoever.
It doesn't get any easier:
1. Connect adapter 1 to the router and connect the device you want to use to adapter
2. You're ready to go!
Networks, computers, Smart TVs, receivers, Set-Top Boxes and much more. Continuous Internet performance for all Internet-compatible devices. Stable Internet--from the basement to the attic. Without lagging! Without dropouts!
Automatic phase shift: This is how the Internet gets to each room and becomes your home network.
Easily expand your network at any time and integrate additional devices into your home network with an additional dLAN® adapter.
Finally you can use everything: Use your printer and hard drives together. Access your music, photos and data or stream HD videos in the highest quality.
Automatic encryption! Active protection against unauthorised access. From the very start!
The exclusive PowerSave technology from devolo provides minimum energy consumption that is continuous, intelligent and entirely automatic.
Includes dLAN® Cockpit management software for the home network option on computers (Windows, Mac OS X, Linux).
Compatible with all adapters of the 200/500 Mbps product series.
Designed, tested and certified in Germany.
Rely on the Number 1--and your global market leader for Powerline home networking. As usual, with maximum performance, exclusive technologies and international patents.
3-year manufacturer´s warranty
- devolo dLAN 500 duo - Starter Kit - powerline adapter kit - wall-pluggable
- Powerline adapter kit
- Packaged Quantity
- 2 (specifications are for single item)
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, HomePlug AV (HPAV)
- Data Transfer Rate
- 500 Mbps
- CSMA/CA
- Auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, HomePlug AV
- Power
- AC 230V (50/60 Hz)
- 6.5 cm x 2.9 cm x 8.1 cm
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 3-year warranty
- Packaged Quantity
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wired
- 500 Mbps
- CSMA/CA
- Encryption Algorithm
- 128-bit AES
- Status Indicators
- Power
Line Properties
- Line Coding Format
- 64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
- LAN: 2 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
- Power Device
- Internal power supply
- Voltage Required
- 3.5 Watt
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 6.5 cm
- 2.9 cm
- 8.1 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
