Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey
Quicklinx: GHJ5WS00 Mfr#: KM7120W-GY-UK
Recommended Use: Leisure
Type: Mouse, Keyboard
Wired / Wireless: Wireless
Colour: Titan grey
Compatibility: PC
14 In Stock
£49.25 ex VAT
£59.10 inc VAT
Dell Multi-Device Wireless Keyboard and Mouse - KM7120W - UK (QWERTY).
  • Conveniently switch
    Seamlessly connect to three PCs. The two Bluetooth 5.0 and 2.4 GHz wireless connection methods allow you to switch easily across your laptop, desktop or 2-in-1 with a click of a button.
  • Built to last
    With many months of battery life, you do not have to be concerned with frequent battery replacements.
  • Precise tracking
    Rapid responses via the 1600 dpi sensor helps you navigate effortlessly, especially across your high-resolution 4K screen. Its optical sensor offers accurate tracking and is ideal for use on most desk surfaces.
  • Easy customization
    Tilt the keyboard to your desired angle to type comfortably. Program shortcuts for your keyboard and mouse for quick navigation to your preferred applications. The intuitive positioning makes them easy to access every time.
Dell Multi-Device KM7120W - keyboard and mouse set - UK - titan grey
Keyboard and mouse set
2.4 GHz, Bluetooth 5.0
Wireless
Localization and Layout
Hot Keys Function
Multimedia, search, home page, volume -, volume +, print screen
Pointing Device
Mouse - wireless - optical
Buttons Qty
7
Titan grey
3-year warranty
Latitude 3310 2-in-1; Precision 5750, 7750; XPS 15 9510
Dimensions (WxDxH) / Weight
Keyboard: 36.3 cm x 12.2 cm x 2.54 cm / 510 g , Mouse: 6.86 cm x 11.4 cm x 4.06 cm / 85 g
Input Device
Wireless
Hot Keys Function
Keyboard Technology
Scissors
Pointing Device
Mouse - wireless
Buttons Qty
7
Movement Detection Technology
Optical
Movement Resolution
1600 dpi
Titan grey
3 AA batteries
Apple MacOS, Microsoft Windows 7, Android, Ubuntu, Google Chrome OS, Windows 8, Windows 8.1, Windows 10
Advanced Exchange Service - 3 years
Dell Latitude 3310 2-in-1 , Dell Precision 5750, 7750 , Dell XPS 15 9510
Type: Mouse
Type: Keyboard
Colour: Titan grey
Compatibility: PC
Brand: Dell
