The Dell External USB Slim DVD +/ - RW Optical Drive is a plug and play disc burning and disc playing solution that you can use with a USB port.
- Dell Slim DW316 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
- DVD±RW (±R DL) / DVD-RAM drive - external
- Interface
- USB 2.0
- 14.4 cm x 13.75 cm x 1.4 cm
- 200 g
- Optical Storage
- Read Speed
- 24x (CD) / 8x (DVD)
- Write Speed
- 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
- Buffer Underrun Protection
- Automatic Buffer Under Run Error Protection Technology
- Media Load Type
- Tray
- Interface
- USB 2.0
- 14.4 cm
- 13.75 cm
- 1.4 cm
- 200 g
Optical Storage
- Read Speed
- Write Speed
- Supported Media Formats
- CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, DVD-Video, DVD-Audio, Super Video CD, Super Audio CD Hybrid Disc
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, M-DISC
- Media Load Type
- Tray
- Buffer Size
- 0.75 MB
- Emergency disc eject hole, Active Optimum Power Control (AOPC), CPRM support
- 1 x USB 2.0
- Cables Included
- 1 x USB cable - external - 60 cm
- MTBF
- 150,000 hour(s)
- Plug and Play
- Software Included
- CyberLink Media Suite CD
- 5 °C
- 40 °C
- 15 - 85% (non-condensing)
- Sound Emission
- 50 dBA
