The Dell KB522 Wired Business Multimedia Keyboard has a newly refreshed ID and has sturdy/robust design with mid-profile keycap for great typing experience, quiet acoustic and durable business daily usage. In addition the Dell KB522 has a set of multimedia and shortcut keys to match customer needs and to help improve efficiency and productivity.
Multimedia keyboard designed for business use
This multimedia keyboard will fulfill your business needs long-term. It features a sturdy, ergonomic design ideal for repetitive, frequent use, as well as multimedia keys, hot keys, and integrated USB ports for efficiency. -
Shortcut and hot keys improve efficiency
The KB522 keyboard features a QWERTY layout and has seven multimedia keys and seven hot keys that activate specific commands. These special keys are designed to match your needs, improving your productivity and efficiency. -
Quiet keys for discreet use
The distracting clacking of keys will no longer be part of your computing experience. The KB522's key design keeps noise to a minimum, allowing you to complete your work in peace. -
Two easy-access high-speed USB ports
The KB522 has two built-in, high-speed USB ports, allowing you to easily and quickly connect devices for high-speed file transfers. -
Ergonomic design with detachable palm rest
Featuring an ergonomic design with a detachable palm rest, the KB522 allows you to find the configuration that works best for you. This design not only increases your comfort, but it maximizes your productivity, since it allows you to work longer.
- Dell KB-522 Wired Business Multimedia - keyboard - QWERTY - UK/Irish - black
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK/Irish
- Hot Keys Qty
- 14
- Hot Keys Function
- Sleep, internet browsing, My Computer, calculator, zoom, e-mail, volume, mute, play/pause
- Removable palm rest, 2-port USB hub, spill-resistant
- Black
- 44.7 cm x 15 cm x 2.5 cm
- 590 g
- 1-year warranty
- Keyboard
- Interface
- USB
Input Device
- Hot Keys Qty
- 14
- Hot Keys Function
- QWERTY UK/Irish
- 44.7 cm
- 15 cm
- 2.5 cm
- 590 g
- 2 x USB
- Black
- Cables Included
- 1 x USB cable
- Limited warranty - 1 year
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
