Dell 3335dn Mono Laser Multifunction Printer
Quicklinx: 7LXCWS00 Mfr#: 210-36877
Versatile and intelligent do-it-all powerhouse for print, copy, scan and fax
The DellTM 3335dn Multifunction Laser Printer lets you print, copy, fax, scan and digitally manage documents--all with one easy-to-use device that won't stretch your budget.
Affordable All-in-One Performance: Print, copy, fax, scan and digitally manage documents--all from one competitively priced multifunction device.
Easy Setup, Easy Use: Built-in wired or optional wireless networking; adjustable 7-inch colour touch screen; convenient scan-to/print-from functions via front USB.
Reliability and Lasting Value: Up to 80,000-page monthly duty cycle.
Printer Type
Networked monochrome laser multifunction printer
Printer Dimensions (H x W x D)
531 x 488 x 438 mm
Printer Weight
22.7 kg
Max Print Speed (Actual print speed will vary with use)
Up to 38 ppm A4
Copy Speed (Actual copy speed will vary with use)
Single document to multiple copies: up to 38 cpm A4
Print Resolution
600 x 600 dpi (Default driver setting), up to 1200 x 1200 dpi effective output
Maximum Monthly Duty Cycle
Maximum 80,000 pages per month
Standard Paper Input
250 sheet (Tray 1)/ 50 sheet (Multi purpose tray)
Maximum Paper Input Capacity
800 sheets + 50 sheet
Standard/Maximum Output Capacity
150 sheet
500 MHz
Memory (RAM)
128 MB standard
Optional Memory
256MB Flash Memory card, SDRAM 128, 256 and 512 MB memory module
Optional Paper Input Accessories
550 sheet drawer
Duplex (Two-sided printing)
Automatic duplex as standard
Media Types Supported
Plain, Recycled, Bond, LetterHead, Preprinted, Coloured Paper, Light Paper, Heavy Paper, Rough/Cotton, Card Stock, Paper labels, Transparencies, Envelopes (smooth), Rough Envelop
Paper Weights Supported
Tray 1: 60- 90 g/m2, MPF: 60-163 g/m2, Optional 550-sheet drawer: 60- 90 g/m2.
Standard Interfaces (Cables not included)
Standard Ethernet 10/100 Base T, Standard USB 2.0 (Hi Speed) - Type B, Front USB 2.0 (Hi Speed) - Type A, Rear USB 2.0 (Hi Speed) - Type A, 1 available internal solution port.
Scan Functionalities
Scan to USB - Quick Scan, Custom Scan, Image Size, Type. Scan to Network Type - Network PC, User Email, FTP Server, Network Server, Network Folder. File Management - 10MB per single file (Auto file split on 10MB incremental change)
Scan Formats
PDF, JPG, BMP, XPS and TIFF
Automatic Document Feeder (ADF)
Duplex Automatic Document Feeder (DADF), 50 sheets (Paper Weight: 60 - 163gsm)
Fax Modes
The modem satisfies the requirements specified in ITU-T (CCITT) recommendations V.34 half-duplex, V.17, V.33, V.29, V.27 ter, V.21 and meets the binary signaling requirements of V.8 and T.30
Fax Speeds
33.6 Kbps
Fax Transmission Speed (LTR)
3 seconds/page
Fax Compatibility
Group 3 / ECM
Printer Language
PCL® 5e Emulation, PCL 6 Emulation, Personal Printer Data Stream (PPDS), PostScript® Level 3 Emulation, HTML, PDF 1.6, XPS, Directimage, HBPv3
Compatible Client Operating Systems
Microsoft Windows - 7, 2000, XP, Server 2003, XP x64, Server 2003 running Terminal Services, 2000 Server running Terminal Services, Server 2003 x64, Server 2003 x64 running Terminal Services, Vista, Vista x64, Server 2008, Server 2008 x64, Server 2008 running Terminal Services, Server 2008 x64 running Terminal Services. Citrix ready, Linux - Ubuntu 7.10, 8.04, Debian GNU/Linux 4.0 , RH Linux WS 3.0,4.0,5.0, SuSE Linux Enterprise Server 8.0, 9.0, 10.0, 11.0, SuSE Linux Enterprise Desktop 11, OpenSuSE 11.1, Novell NetWare 5.1, 6.x. Macintosh version OS X 10.2-10.6, Unix - Sun Solaris 8,9,10.0, HP UX. Citrix Metaframe Presentation Server 3.0, 4.0 & 4.5 (compatible) and 5.0 (certified) (TBD), SAP.
Printer Management Software
Dell Printer Configuration Web Tool (EWS), Dell OpenManage Printer Management Tools. IP Setup Utility (IPSU), Printer Alert Utility (PAU), Twain driver version v-1.8/v-1.0 (for network/local), WIA driver standard, Scanback Utility
