Connect to a high-speed wireless network with D-Link's Wireless N 150 High-Gain USB Adapter. This adapter uses Wireless N 150 technology to provide increased speed and range over the wireless standard, giving you a faster, more reliable connection, making it ideal for email, web browsing and file sharing in the home.
High-speed wireless networking
Connect to a high-speed wireless network with the D-Link Wireless N 150 High-Gain USB Adapter and enjoy surfing the web, checking email, and chatting with family and friends online. The DWA-127 uses Wireless N 150 technology, which offers faster speeds and greater range than 802.11 g/b providing you with a faster and more reliable wireless connection. -
Enhanced wireless range
DWA-127 Wireless N 150 High-Gain USB Adapter has a high-gain antenna that provides a boosted signal reception so that you can enjoy wireless coverage over a wider distance than with a regular wireless adapter. The antenna is also rotatable so you can eliminate dead spots by fine-tuning the antenna positioning to get the best available wireless connectivity. -
Connect securely to your wireless network
To protect your data and maintain your privacy while surfing the web, the Wireless N 150 High-Gain USB Adapter supports WEP, WPA, and WPA2 encryption which enable you to connect to and access a secure wireless network. This allows you to securely shop and pay online and check email with confidence. -
Easy to install and connect
D-Link's quick setup wizard enables easy setup of your DWA-127 so you can get connected quickly. Wi-Fi Protected Setup (WPS) allows you to set up a secure wireless connection with just the push of a button. This eliminates the need for complicated configuration, thus simplifying setup and saving you time and hassle. The DWA-127 has a USB interface so it can be connected to both a notebook or a desktop computer.
- D-Link Wireless N DWA-127 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.5 cm x 1.4 cm x 21 cm
- Data Link Protocol
- 802.11b/g/n
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3
- Designed For
- D-Link DIR-600
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Status Indicators
- Link/activity
- WPS
Aerial
- Antenna Qty
- 1
- Directivity
- Omni-directional
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC Class B certified, C-Tick, IC
- OS Required
- System Requirements Details
- Windows XP/Vista/7 HD 20 MB
- 1.5 cm
- 1.4 cm
- 21 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Designed For
- D-Link DIR-600
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.08 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £19.26 |
