The DPR-1040 Wireless G USB Multifunction Print Server is a compact and versatile print server ideal for home office, school and business use. Supporting scan, fax, and print functions, this device gives you the option of sharing one USB multifunction printer wirelessly between multiple users. This print server is based on the 802.11g wireless specification: it transfers data at speeds of up to 54 Mbps.
The DPR-1040 supports a wide range of network OS including: Windows 95/98/ME/NT 4.0/2000/XP, Apple MacOS with AppleTalk, Linux, Solaris, SCO Unix, IBM AIX and NetWare 5.x native ND S.
The Internet Printing Protocol (IPP) supported by the DRP-1040 allows remote users to output files to their home or office printer even when they are off site.
The DPR-1040 includes D-Link's Click'n Connect software (DCC). This intuitive wizard is run directly from the product CD-ROM. In a few simple steps, it takes you through setting the Print Server up and configuring the attached printers (18 languages supported).
- D-Link Wireless G DPR-1040 - print server - USB 2.0 - 10/100 Ethernet
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- 10/100 Ethernet
- 5.8 cm x 9 cm x 2.7 cm
- 82 g
- Localisation
- United Kingdom
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 802.11b/g
- TCP/IP, LPR/LPD, RAW
- Frequency Band
- 2.4 GHz
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0
- System Requirements
- Microsoft Windows NT 4.0, UnixWare, IBM AIX, SunSoft Solaris, HP-UX, SunOS, SCO Unix, Linux, Novell NetWare 5.x, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.4.x, Microsoft Windows 2000 / ME / XP/ Vista
- 2-year warranty
- Print server
- Form Factor
- External
- USB 2.0
- Localisation
- United Kingdom
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wireless, wired
- Cabling Type
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Remote Management Protocol
- IPP
- Frequency Band
- 2.4 GHz
- Status Indicators
- Port status, power
- DHCP support, WPS
Aerial
- Antenna
- Internal
- Antenna Qty
- 1
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x USB 2.0
- Cables Included
- 1 x network cable (external)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- FCC Class B certified, CSA, C-Tick, IC
- Power Device
- Power adapter - external
- OS Required
- 5.8 cm
- 9 cm
- 2.7 cm
- 82 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95%
