D-Link 4-Port KVM Pro-Connect Switch
Customer rating: 1.0* (Write a review)
Quicklinx: 36ZTWS00 Mfr#: DKVM-4K
If you need to control several computers at the same time (such as in a computer room), the DKVM-4K 4-port KVM Switch saves you the money and space by allowing you to control you're the computers from a set of keyboard, monitor and mouse. You may have a better, bigger monitor and want to connect all 4 PCs to it, the DKVM-4K allows you to do this.
The DKVM-4K allows you to manage port traffic and boot up the attached PCs. A control button located on the top of the DKVM-4K gives you one touch access to your attached PCs. Featuring hot-plug, auto-scan, keyboard hot-keys and audible feedback, this switch makes it simple to manage all of your computers.
The DKVM-4K supports VGA, SVGA, and MultiSync monitors at up to 2048 x 1536 resolution. Support for Microsoft IntelliMouse is provided.
D-Link DKVM 4K - KVM switch - 4 ports
Subtype
KVM
Ports
4 x KVM port(s)
KVM Users Qty
1 local user
10.2 cm x 17.8 cm x 3 cm
0.3 kg
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
2048 x 1536
Status Indicators
Port status
4 x keyboard (PS/2) , 4 x mouse (PS/2) , 4 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x VGA HD-15
2 x keyboard / mouse / video cable - 1.8 m
10.2 cm
17.8 cm
3 cm
0.3 kg
50 °C
0 - 80%
Customer reviews
Write a review for the D-Link 4-Port KVM Pro-Connect Switch here!
question - cables
Reviewed by Anonymous Review Posted 02/05/2006
Question - does this actually come with cables? (above it says it does, but the dlink website says different) Anyone?
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
