PowerDirector 14 is the fastest and most flexible video editing software in the world. Powered by the 64-bit TrueVelocity™ engine, PowerDirector provides unparalleled speed in rendering HD videos – including support for the latest 4K UltraHD and H.265/HEVC formats. PowerDirector provides the easiest and most streamlined way to create sophisticated and professional looking movies.
PowerDirector includes over 500 effects, including animated themes, title effects, transitions, animated particles and PiP objects. Users can customize and control realistic non-linear motion for PiP objects and titles, and add new opening and ending effects.
Video editing plug-ins can stimulate and save time. PowerDirector supports plug-ins from leading designers NewBlue, Pixelan and proDAD, and comes with over US$900 worth of premium effects and templates that provide a huge variety of creative options for video editors.
TrueVelocity 5 leverages hardware and software technologies to speed up video processing and outperform all others. TrueVelocity is optimized for modern CPU and GPGPU hardware platforms from Intel, AMD and NVIDIA to maximize memory allocation and usage.
The all new Action Camera Center brings together the ultra-powered features action enthusiasts need to create high impact videos. Use it to stabilize shaky action video, correct fish-eye distortion, and fix color problems. You can also apply slow motion effects, or freeze & zoom to footage highlights
PowerDirector Ultimate offers a combination of high-end performance and features found in pro-level software, wrapped in an easy-to-use interface. PowerDirector’s customizable design tools and premium plug-ins are running on the world's fastest video rendering engine, while the new Action Camera center provides all the tools needed by action sports enthusiasts.
Operating System: Windows 10/8.1/8/7/VISTA (SP2)
Screen Resolution: 1024 x 768, 16-bit color or above
Memory: 2GB required, 3GB or above recommended for 32 bit OS, 6GB or above recommended for 64 bit OS
Hard Disk Space: 8.5 GB required
Graphics Support: Intel® 945 GM or later, 64 MB-VRAM or above
Processor: Intel Core i5, AMD Phenom II x4 or above for Blu-ray 3D. For 2K/4K video editing: Intel Core™ i7 or AMD Phenom II X4 with 64-bit OS
An internet connection is required for initial software activation, video codec activation and social media services
Transition designer
Create unique transitions from any image or logo using alpha channel masks to control their shape. -
Title designer
Customize a title's motion, font size, gradient color, border, blur level, transparency and reflection. -
PiP designer
Overlay animated objects on your videos and use simple transforming tools to create engaging video collages -
Theme designer
Choose from more than 30 animated theme templates and simply drag 'n' drop your own footage in to create professional animated slideshows -
MultiCam designer
Combine and switch between up to four camera shots in one synced video on-the-fly. -
Menu designer
Create fully customizable disc menu layouts, menu structures, font styles and chapter thumbnails. -
Record your PC screen with audio
CyberLink Screen Recorder lets you capture game play, create instructional videos, or record video chats with family & friends at 30 frames per second. With customizable recording settings, and the ability to also record system sounds and voice, Screen Recorder adds another handy tool to a video maker's arsenal. -
Standalone Recorder for quick captures
Screen Recorder also installs as a standalone app, letting you quickly capture and save screen recordings without launching PowerDirector. You can capture everything on the screen, a specific application only, or even a custom section of your screen in either 16:9 or 4:3 aspect ratio, as well as highlight mouse clicks in a range of colors. -
Over 500 pro-quality effects
PowerDirector provides over 500 effects and templates to polish your video creation. Add transition effects and stylish video effects to make your videos unique. Overlay animated titles, PiP objects and amazing particle effects to your video and make it truly shine! -
Premium effect plugins and templates
PowerDirector 14 Ultimate also includes several premium effect and template packages to further enrich your video creation. Bring more cinematic tone to your videos with more 3rd party plug-ins from world-renowned sources such as NewBlueFX, Pixelan and proDAD. -
TrueVelocity 5 engine featuring the latest SVRT 4, OpenCL, and Multi-GPGPU technologies
TrueVelocity 5 is an extreme, 64-bit powerhouse, leveraging hardware and software technologies to speed up video processing and out-perform its rivals. Optimized for modern CPU and GPGPU hardware platforms from Intel, AMD and NVIDIA, TrueVelocity maximizes memory allocation and usage, while reducing latency through feature optimization. The improved system efficiency enables HD footage to preview more smoothly and render faster. -
Latest format and codec support
As always, PowerDirector provides a comprehensive list of video and audio formats so that your video making experience is as easy and trouble-free as possible. On top of the latest and greatest formats and codecs like 4K UltraHD, AVCHD 3D/Progressive, XAVC-S and H.265, PowerDirector 14 has significantly improved video performance when working with the popular WMV format, as well as adding FLAC audio editing support - the format of choice for people who care about sound quality. -
Action camera center
PowerDirector's new Action Camera Center is your extreme video editing toolkit, bringing together features action enthusiasts need to create high impact videos. -
Motion tracking
Tracking people or objects in video footage can be a complicated task in other video editing software. PowerDirector has simplified the process from start to finish, making it easy to add layers of creativity and sophistication to you projects. -
Edit up to 100 tracks simultaneously
The MultiCam Audio Sync feature allows you to synchronize up to 100 timeline tracks by audio. That means you can easily create MultiCam collages simply by transforming video tracks into PiP (picture in picture) objects. -
Import, edit and export high frame rate video
Import 120/240fps slow motion footage from your iPhone, GoPro or other action sports cameras. Add titles or effects, and use the new Action Camera Center to edit your video. Playback your video inside PowerDirector, so that you can preview it, stutter-free before you produce. Produce and export your high frame rate video fast with hardware accelerated rendering. -
20GB CyberLink Cloud service
CyberLink Cloud is designed to work perfectly with PowerDirector to safely store your project files, videos and other files using the latest in cloud technology.
- PowerDirector Ultimate (v. 14) - box pack - 1 user
- Product Type
- Box pack
- Category
- Creativity application - video editing & production
- Version
- 14
- Licence Qty
- 1 user
- Platform
- Windows
- Distribution Media
- DVD-ROM
- Category
- Product Type
- Box pack
- Version
- 14
- Platform
- Windows
- DVD-ROM
Licencing
- Licence Qty
- 1 user
- Supported OS
- Microsoft Windows Vista SP2, Microsoft Windows 7 / 8 / 8.1 / 10
- Hardware Requirements
- Microsoft Windows Vista - Pentium 4 - 3 GHz - RAM 2 GB - HD 8.5 GB , Microsoft Windows Vista - Athlon 64 X2 RAM 2 GB - HD 8.5 GB
- Additional Requirements
- DVD-ROM, Internet connection, 128 MB video memory, 16-bit graphics card, 1024 x 768 monitor resolution, Windows Media Player 9.0 or later
