Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
- Crucial - DDR3 - module - 4 GB - DIMM 240-pin - 1333 MHz / PC3-10600 - registered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1333 MHz (PC3-10600)
- Latency Timings
- CL9
- Registered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- HP 500658-B21, IBM 44T1483, IBM 44T1488, DELL A2626093, DELL A2626076, DELL A2626060, DELL A2626072, DELL A2626098, HP FX621UT, HP FX621AA, DELL A2626083, DELL A2862069, DELL A2862074, Sun X4651A, Sun X8338A, Sun X4654A, Sun X4652A, HP 500658-S21, IBM 40W4553, IBM 40W4556, IBM 44T1498, HP 500203-061, DELL A2626067, DELL A2937059, Kingston KCS-B200A/4G, Kingston KTH-PL313/4G, Kingston KTL-TS313/4G, Kingston KTM-SX313/4G, Kingston KTM-SX313L/4G, Kingston KTS-SF313/4G, Kingston KVR1333D3D4R9S/4GI, Kingston KVR1333D3D4R9SL/4G, Kingston KVR1333D3D8R9SK2/4GI, Crucial MT18JSF51272PDZ-1G4D1, Crucial MT36JSZF51272PY-1G4D1, Crucial MT36JSZF51272PZ-1G4F1, Cisco N01-M304GB1, Sun X5870A, Sun X4673A, Sun X5867A, Kingston KTD-PE313/4G, HP 500203-561, Kingston KVR1333D3D4R9S/4G
- Limited lifetime warranty
- Designed For
- ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D18; Intel Server Board S5500, S5520; Workstation Board S5520; SUPERMICRO X8DA3, X8DAH+, X8DAH+-F, X8DAi, X8DT3, X8DT3-F, X8DTH-i, X8DTH-iF, X8DTi, X8DTi-F, X8DTi-LN4F, X8DTU, X8DTU-F; Tyan S7002, S7010, S7012, S7016, S7025
- Capacity
- 4 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL9
- ECC
- Registered
- Module Configuration
- 512 x 72
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D12X, Z8PE-D18 , Intel Server Board S5500BC, S5500HCV, S5500WB, S5520HC, S5520UR , Intel Workstation Board S5520SC , SUPERMICRO X8DA3, X8DAH+, X8DAH+-F, X8DAi, X8DT3, X8DT3-F, X8DTH-i, X8DTH-iF, X8DTi, X8DTi-F, X8DTi-LN4F, X8DTU, X8DTU-F , Tyan S7002AG2NR, S7002G2NR-LE, S7002GM2NR-LE, S7002WGM2NR, S7010AGM2NRF, S7012GM4NR, S7016GM3NR, S7025AGM2NR
