Crucial 2GB 184-Pin DIMM PC2700 ECC Registered CAS 2.5
Quicklinx: 4L0VWS00 Mfr#: CT25672Y335
Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
Crucial - DDR - module - 2 GB - DIMM 184-PIN - 333 MHz / PC2700 - registered
Memory module
2 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
Registered
Voltage
2.5 V
IBM 41P9347, DELL A0743717, DELL A0743718, DELL A0743719, DELL A0743721, DELL A0743723, DELL A0743724, DELL A0743725, Kingston KFJ-TX200S2/2G, Kingston KTC7494/2G, Kingston KTH8348/2G, Kingston KTM3281/4G, Kingston KVR266X72RC25/2G, Kingston KVR266X72RC25L/2G, Kingston KVR333D4R25/2G, Kingston KVR333D4R25/2GI, Kingston KVR333X72BRC25/2G, Crucial MT36VDDF25672Y-335F3, Fujitsu S26361-F3084-E522, HP 301044-B21, HP 313305-B21, HP 358349-B21, HP 300702-001, DELL A0743720, IBM 33L3288, IBM 33L3287
ASUS PP-DLW, SK8N, SK8V; Gigabyte GA-K8NNXP-940; Intel Server Board SE7320SP2, SE7320VP2, SE7520BD2, SE7520JR2, SE7525GP2
2 GB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Speed
333 MHz (PC2700)
Latency Timings
CL2.5
ECC
Registered
Module Configuration
256 x 72
Voltage
2.5 V
Compatible Slots
1 x memory - DIMM 184-PIN
ASUS PP-DLW, SK8N, SK8V , Gigabyte GA-K8NNXP-940 , Intel Server Board SE7320SP2, SE7320VP2, SE7520BD2, SE7520JR2, SE7525GP2
