Crucial 256GB m4 SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 7GL2WS00 Mfr#: CT256M4SSD2
The Crucial m4 offers mobile and desktop users scorching fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
The best just got better.
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds, groundbreaking SATA SSD computing, and unparalleled performance for the dollar.
Latest and greatest.
Designed for client computing, the Crucial m4 SSD delivers faster boot and application load times for mobile and desktop users alike. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the second-generation SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Memory Experts.
Delivering on the highest quality based upon Micron's leading-edge NAND media, the Crucial brand of SSDs has long been synonymous with reliability and high performance. And because we're part of Micron, the m4 was bred and built entirely in-house. So you can rest assured you'll get one of the highest quality products available--from the company that knows memory.
Why an SSD?
SSDs provide many benefits over traditional hard drives. You'll enjoy reduced power consumption, less heat generation. Because they have no moving parts, SSDs are quiet, more lightweight, and they're rugged and reliable even in the most demanding operating environments or temperature extremes.
Guaranteed Compatible.
Crucial m4 series employ a standard hard drive interface and dimensions, so it is an easy storage upgrade for most notebooks. We guarantee compatibility.
Benefits
  • Performance--Improve boot up and application load times
  • Reliability--Withstand extreme shock and vibration
  • Compatibility--SATA 6Gb/s, backward compatible to SATA 3Gb/s
  • Quality--Crucial is a trusted name in DRAM and SSD products
  • Three Year Limited Warranty
Performance: 256GB* SATA 6Gb/s
  • Sequential READ: up to 415MB/s
  • Sequential WRITE: up to 260MB/s
  • Random 4k READ: 50K IOPS
*Some of the listed storage capacity is used for formatting and other purposes and is not available for data storage. 1GB equals 1 billion bytes. 1Typical I/O performance numbers as measured using Iometer with a queue depth of 32 and write cache enabled. Iometer measurements are performed on a 8GB span. 4k transfers used for Read/Write latency values. System variations may affect measured results.
  • Enhanced durability
    Built with multi-level cell (MLC) NAND flash memory, this solid state drive offers improved endurance and longevity compared to traditional hard drives.
  • Seamless integration
    Featuring a Serial ATA-600 interface, the drive ensures a smooth connection with a wide range of devices, facilitating easy installation and compatibility.
  • Compliance assured
    Adhering to FCC, RoHS, and UL standards, this solid state drive meets rigorous regulatory requirements, ensuring a reliable and safe computing experience.
Crucial m4 - solid state drive - 256 GB - SATA 6Gb/s
Solid state drive - internal
256 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/8H
SATA 6Gb/s
S.M.A.R.T.
70 mm x 101 mm x 9.5 mm
75 g
3-year warranty
256 GB
2.5" x 1/8H
SATA 6Gb/s
S.M.A.R.T.
70 mm
101 mm
9.5 mm
75 g
Performance
Internal Data Rate
500 MBps (read) / 260 MBps (write)
4KB Random Read
45000 IOPS
4KB Random Write
50000 IOPS
Reliability
MTBF
1,200,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
UL, FCC, RoHS
Limited warranty - 3 years
70 °C
Shock Tolerance
1500 g @ 1ms (operating) / 1500 g @ 1ms (non-operating)
