- Crucial - DDR3 - kit - 12 GB: 3 x 4 GB - DIMM 240-pin - 1066 MHz / PC3-8500 - unbuffered
- Product Type
- Memory kit
- Capacity
- 12 GB: 3 x 4 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1066 MHz (PC3-8500)
- Latency Timings
- CL7
- Unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- OEM Manufacturer Equivalent Part Number
- Kingston KTA-MP1066K3/12G, Kingston KVR1066D3E7SK3/12G
- Limited lifetime warranty
- Designed For
- ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D18; DFI DK X58, UT X58; Intel Server Board S5500; SUPERMICRO C7X58, X8DAH+-F, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4; Tyan S7002, S7010, S7012, S7016, S7025
- Capacity
- 12 GB: 3 x 4 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL7
- ECC
- Unbuffered
- Module Configuration
- 512 x 72
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 3 x memory - DIMM 240-pin
- Designed For
- ASUS Z8NA-D6, Z8NR-D12, Z8PE-D12, Z8PE-D12X, Z8PE-D18 , DFI DK X58-T3eH6, UT X58-T3eH8 , Intel Server Board S5500BC, S5500WB , SUPERMICRO C7X58, X8DAH+-F, X8SAX, X8ST3-F, X8STE, X8STi, X8STi-F, X8STi-LN4 , Tyan S7002AG2NR, S7002G2NR-LE, S7002GM2NR-LE, S7002WGM2NR, S7010AGM2NRF, S7012GM4NR, S7016GM3NR, S7025AGM2NR
