Creative Sound Blaster Roar
Quicklinx: C3TWWS00 Mfr#: 51MF8170AA005
The Roar SR20 features one amplifier driving the lows and mids, and with another driving the high frequencies, to deliver uncompromising clear, high definition, well balanced music with impressive bass.
The Roar SR20 incorporates far-field high frequency drivers that project audio further than most other speakers in its class. It is further complemented by the boxer-style layout, which also delivers a room-filling, non sweet spot-specific audio experience. Perfect, when you're lacking in resources and looking for minimal effort to "Work the Room".
  • Built bi-amplified
  • Compact, powerful, high frequency drivers
    The Roar SR20 features two carefully selected durable, lightweight, 1.5" high frequency drivers that deliver balanced highs for providing far-field high frequency dispersion.
  • Clean, powerful, bass
    With luxury of an active crossover thanks to its Bi-amplified design, the Roar SR20 features an active high excursion 2.5" driver that pumps out impressive bass, directing the audio upwards which stabilizes the speaker and also provides for a wider soundstage that is less acoustic sweet spot-dependant.
  • Comes with even more bass enhancement
    Besides an active driver, the Roar SR20 is further matched with side firing, dual opposing passive radiators which further enhance bass levels while widening the soundstage. If bass levels can be measured by wind speed in knots... expect to witness some knock outs, and not to mention... dramatic expressions.
  • Acoustically optimized speaker design
    Designed for purpose, the acoustic enclosure features a rigid monocoque endo-skeletal chassis that has fewer internal components that can vibrate individually. A good man with fine leadership abilities has the power to inspire, to motivate change and action.
  • Delivering space filling audio
  • ROAR: instant additional audio power
    Great designs follow a philosophy of simplicity and functionality. A User-oriented design does not bother users with non-essentials; it focuses on solving problems and improving a given situation for its user.
  • Equipped with a full range of connectivity options
    The Roar SR20 comes with NFC connectivity for fuss free, easy pairing, and Bluetooth wireless technology for wireless audio. Besides being coupled with high definition audio codec like aptX and AAC, the Roar SR20 has a built in microphone that records audio, mobile voice calls and even gives the option of playing music via a microSD card. The Roar SR20 also comes with a 3.5 mm Aux-in for connectivity to other analog audio devices.
  • Creative multipoint
    Connect multiple Bluetooth devices! With Creative Multipoint, you can simultaneously connect two Bluetooth stereo devices to the Roar SR20 and easily toggle between them.
  • Sound blaster USB audio
    The Sound Blaster Roar is not just a wireless speaker for smart devices. Users can connect it to their PCs or Macs via USB to enjoy clear digital audio for their desktops or laptops. Connecting the speaker via USB enables advanced PC audio processing via the downloadable software, sound blaster control panel and full access to the SBX Pro Studio suite of technologies that intelligently enhance audio in real time.
  • An array of other innovative features
    The Roar SR20 is designed with useful features such as a dual-purpose battery that sustains its portability and charges your smart device; a one-touch siren feature for grabbing attention; Bedtime mode which is excellent for soothing music before gradually reducing its volume, and life-saver mode that plays random tones and sound bytes to keep you alert.
Creative Sound Blaster Roar SR20 - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Digital recorder
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Audio Formats
WAV, WMA, AAC, MP3, apt-X
Speaker Details
Speaker - stereo x 2 - active , Speaker - subwoofer - active
Built-in Decoders
SBC decoder, aptX
Speaker battery rechargeable - Lithium Ion
20.2 cm x 11.5 cm x 5.7 cm
1.1 kg
Digital recorder
Flash memory card
Hands-Free Function
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Built-in Decoders
SBC decoder, aptX
Audio Formats
Controls
Power on/off, volume, call answer
Interface Type
USB
Additional Features
Bi-amplified
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x tweeter driver - 1.5" , Speaker: subwoofer driver - 2.5" , Speaker: 2 x Passive Radiator - side-firing
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power output (4 PIN USB Type A)
Power adapter, micro-USB cable
Power Source
USB, battery
Rechargeable - Lithium Ion
Capacity (Ah)
6000 mAh
Run Time (Up To)
8 hour(s)
20.2 cm
11.5 cm
5.7 cm
1.1 kg
