Creative Muvo Mini Portable Water-resistant Wireless Speaker (RED)
Quicklinx: B6HFWS00 Mfr#: 51MF8200AA007
Get ready to enjoy some splashing fun with your audio! Weather-tested the Creative MUVO mini is also water and dust resistant, ensuring nothing stops you from enjoying your music in wild weather, or the wildest pool party! The Creative MUVO mini is designed to be small and compact for you to take it everywhere with you. Let the adventure begin! Don't underestimate the audio prowess of the Creative MUVO mini because of its size! This speaker pumps out surprisingly loud and clear stereo audio with bass deep enough to get everyone dancing to your playlist.
  • Poolside cool
  • Bring the party with you
  • Get the party started
  • Don't let the party stop
    Keep that playlist going; the Creative MUVO mini has a long battery life. When it runs out of juice, simply charge it via its Micro USB port.
  • Connect wirelessly
    Simply tap on the Creative Mini to pair your NFC-enabled device for fuss-free pairing. Alternatively, you can also connect your device via Bluetooth.
  • Aux-in
    The Creative MUVO mini comes with an integrated 3.5mm aux-in for connection to other analog audio devices.
  • Toggle between your playlist and your calls
    Switching between your phone calls and your playlist is so hassle-free with the Creative MUVO mini. The speaker is integrated with a built-in microphone which enables it to double up as a speakerphone. When you are done with your call, simply switch back to your playlist with the tap of a button. How easy is that?
Creative MUVO mini - speaker - for portable use - wireless
Speaker - for portable use
Protection
Waterproof
Speaker Type
Active
Amplifier
Integrated
Bluetooth, NFC
Speaker Details
Speaker - stereo x 2 - active
Red
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
19 cm x 5.9 cm x 3.7 cm
285 g
1-year warranty
Hands-Free Function
Protection
Waterproof
Enclosure Colour
Red
Speaker System
Speaker Type
Active
Amplifier
Integrated
Bluetooth 4.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Controls
Power on/off, volume
Additional Features
Sub Band Coding (SBC)
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x full-range driver , Speaker: Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Micro-USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
2200 mAh
19 cm
5.9 cm
3.7 cm
285 g
Limited warranty - 1 year
