Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select  184 Pin Desktop Memory Module
Customer rating: 5.0* (Write a review)
Quicklinx: 3PCLWS00 Mfr#: VS1GB400C3
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
CORSAIR Value Select - DDR - module - 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
Memory module
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
ABIT AN8, Fatal1ty AN8, GD8; AOpen AX4BR; ASUS A8N, P4P800; ECS 661, 755, 848, 865, 915, K8M800, K8T800, KM400, KT600, KV1, KV2, L4IGEA2, N2U400, P4IBAD2, PM800, PT800, RS400, RS480; EPoX EP-9HEAI; FIC VC37; Gigabyte GA-8GVMT4, 8I845, 8I848, 8PE800; MSI K8N Neo3-F; SOYO SY-P4I865, P4I875, P4RS350
1 GB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT AN8, AN8 SLi, AN8 Ultra, AS8-3rd Eye, AX8, BE7, Fatal1ty AN8, Fatal1ty AN8 SLi, GD8, IG-80, IG-81, KU8, KV8 Pro-3rd Eye, KW7, KW7-G, NF8, NF8-V, SG-80, SI-1Ns42, SI-1Ns60, VA-20, WI-1P , AOpen AX45F-4DL, AX4BR-U, AX4SG-UL, AX4SPE-UL, i865Gm-I, i865Gm-IL, i865PEa-7IF, i915Ga-E, MX46-800L, MX4SG-4DL, MX4SG-4DN, MX4SGI-4DL, MX4SGVI-N, n250a-FR, s651m, s661FXm, s661FXm-S , ASUS A7S8X-MX, A7V266E/AA, A7V600 SE, A8N-E, A8N-SLI Deluxe, A8N-SLI Premium, A8V-E Deluxe, K8N, K8S-MX, K8V-X, P4P800 SE, P4P800S-X, P4P800-X, P4PE2-X, P4S800D-X, P4U800-X, P5RD1-V, P5RD1-V Deluxe , ECS 661FX-M7, 741GX-M, 755-A, 848P-A7, 865G-M, 865-M7, 865PE-A7, 915G-A, 915G-M, 915P-A, K8M800-M2, K8T800-A, KM400-M2, KN1 Extreme, KT600-A, KV1 Deluxe, KV2 Extreme, L4IBME, L4IBMG2, L4IGA2, L4IGEA2, L4IGEM2, L7VTM, N2U400-A, NFORCE4-A939, P4IBAD2, PM800-M2, PT800CE-A, RS400-A, RS480-M , EPoX EP-5EGA+, EP-8HDA5+, EP-8RDA6+ Pro, EP-8VTAI, EP-9HEAI, EP-9NDA3+, EP-9NPA+, EP-9NPA+ Ultra, EP-9NPAJ , FIC K7-NF2 400 PRO, K8M-800M, K8M-800T, K8M-NF3 250, KT-400A, P4-865P Ultra, P4I-845GV, P4M-800T2, P4M-865G Max III, P4M-865GV, P4M-865P ULTRA, P4M-915GD1, P4M-915GD2, P4M-915PD1, P4M-915PD2, PTM865, VC37GV, VG33, VI35L , FIC Crusader CS-P4M865G , Gigabyte 8S648FXP-RZ, GA-7NF-RZ, GA-7VT600F, GA-8GVMT4, GA-8I845GV-C, GA-8I845PE Pro, GA-8I848P, GA-8I865P, GA-8I865PE-L, GA-8I865PE-TW, GA-8I865P-G, GA-8I915P Duo Pro-A, GA-8IPE1000 Pro2-W, GA-8IPE1000MT, GA-8PE800 PRO-R, GA-8TRS350MT, GA-K8N ULTRA-SLI, GA-K8NS Pro, GA-K8NXP-9, GA-K8NXP-SLI , Intel Desktop Board D845PECE, D865PERC, D865PESO, D915GAG, D915PSY , MSI 865GVM2-LS, 865PE NEO3-F, 915G Combo-FR, 915GM-FR, 915PM-ILR, K8N Neo3-F, K8N Neo4 Platinum/SLI, K8N Neo4-F, K8T Neo2-FIR, PT880 Neo-FSR, RS480M2-IL, RX480M2 , SOYO SY-CK8 DRAGON Plus, SY-K7VME, SY-KT880 DRAGON 2, SY-P4I 845PE, SY-P4I865PE Plus DRAGON 2 (Prescott-Ready), SY-P4I875P DRAGON 2 Black Label (Prescott-Ready), SY-P4RC350, SY-P4RS350, SY-P4VTP
Customer reviews
Write a review for the Corsair 1GB (1x1GB) DDR1 400Mhz CL3 Value Select 184 Pin Desktop Memory Module here!
deceptive picture
Reviewed by Anonymous Review Posted 26/12/2005
fast memory for the price. this is NOT 2 x 512m as the picture would suggest, it is 1 x 1024m.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Great
Reviewed by . Review Posted 15/02/2006
Easy to install system picked it up straight away although had to manually change the speed in bios
  • Overall 5*
  • Ease of use 4*
its hot stuff literally
Reviewed by Gaz Hart. Review Posted 08/06/2006
i bought one of last month and have no problems with the memory itself but the actual heat ot gives off has resulted in buying a new case, the 1 fan and my old case could not dissipate the heat however my new case has a fan on the rear and side and can cope with the heat
  • Overall 5*
  • Ease of use 3*
  • Value for money 4*
Read all 5 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
