Corsair Flash Voyager USB 3.0 - USB flash drive - 64 GB - USB 3.0
Quicklinx: 82NJWS00 Mfr#: CMFVY3S-64GB
Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
  • Flash Voyager durability
    As fast as USB flash drives are, copying files always seems to take a little longer than you'd like. The advent of the USB 3.0 interface puts an end to that. You can move files back and forth in a fraction of the time it takes with standard USB 2.0 flash drives, and the proprietary water-resistant rubber housing helps keep those files safe.
  • USB 2.0 compatible
    Of course, Flash Voyager USB 3.0 is backward compatible with USB 2.0. Even if you haven't yet upgraded your PC to USB 3.0, it's still a great choice for convenient, reliable portable file management, and the additional performance will be ready when your PC is.
  • Durable and shock-resistant
    The finger-friendly ergonomics of the Flash Voyager USB 3.0 will make it the USB flash drive that you'll want to take with you everywhere. Reliability is essential. Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager USB 3.0 is water-resistant.
CORSAIR Flash Voyager USB 3.0 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Linux, Apple MacOS X, Microsoft Windows
5-year warranty
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 85 MB/s
Write Rate
Up to 70 MB/s
Interface Type
USB 3.0
Shockproof, water resistant
Limited warranty - 5 years
