Corsair 850W Corsair Modular PSU
Quicklinx: 5KBNWS00 Mfr#: CMPSU-850HXUK
Corsair Professional series power supplies set a new standard by which all premium PSUs must be judged. Designed and engineered using cutting-edge technology, each Corsair Professional series power supply is built to the highest quality standards, and delivers the features and performance that technology enthusiasts demand.
The Corsair Professional series HX850W PSU utilizes advanced DC-to-DC circuitry and meets 80 Plus Silver certification standards for up to 90% energy-efficiency, reducing wasted energy and lowering the amount of excess heat generated. Corsair Professional series power supplies are built using industrial grade electrical components, ensuring the stable, clean and reliable voltages that are essential for high-end gaming PCs and workstations.
Corsair Professional series power supplies boast an innovative cabling configuration that uses low-profile, flat modular cables that reduce air friction to help maximize airflow through the computer chassis. The modular design also simplifies installation as it allows unprecedented flexibility in using only those cables which are needed.
CORSAIR Professional Series HX850W - power supply - 850 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.3/ EPS12V 2.91
80 PLUS Certification
80 PLUS Silver
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
+3.3V - 25 A , +5V - 25 A , +12V - 70 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 12 x 15 pin Serial ATA power , 12 x 4 PIN internal power , 2 x 4 PIN mini-power connector
Modular Cable Management
15 cm x 18 cm x 8.6 cm
7 years warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 100-240 V
Input Voltage Range
AC 90 - 264 V
Frequency Required
50/60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
850 Watt
Output Current
80 PLUS Silver
MTBF
100,000 hours
Solid capacitors, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, semi-modular
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC
Limited warranty - 7 years
50 °C
15 cm
18 cm
8.6 cm
