Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Great looking, great overclocking memory
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig. -
Optimized for compatibility with the CPUs and motherboards
Vengeance memory is designed specifically for the latest CPUs. The 1.5V VDIMM spec ensures you get the performance you expect, even without increasing memory voltages.
- CORSAIR Vengeance Pro Series - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 2400 MHz / PC3-19200 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2400 MHz (PC3-19200)
- Latency Timings
- CL11 (11-13-13-31)
- Aluminium heat spreader, dual channel, Intel Extreme Memory Profiles (XMP 1.3), Vengeance red heatspreader, unbuffered
- Voltage
- 1.65 V
- Limited lifetime warranty
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- Non-ECC
- Voltage
- 1.65 V
- RAM Performance
- Tested - 2400 MHz - 1.65 V - 11-13-13-31 , SPD - 1333 MHz - 1.5 V - 9-9-9-24
- Compatible Slots
- 2 x memory - DIMM 240-pin
