For small business employees to communicate effectively with suppliers and customers in today's competitive business environment, they need ready access to information, updated in real time. They also need to stay connected - to each other and to the business applications they use to do their jobs. With the right solution, your business can collaborate more effectively and problem-solve like never before.
The Cisco Unified Communications 560, a central part of the Cisco Smart Business Communications System (SBCS), is an affordable unified communications appliance that provides voice and data communications, voicemail, automated attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, email, and customer relationship management (CRM) programs. This easy-to-use solution supports up to 104 users and provides flexible deployment options based on your needs, supporting a wide array of IP phones, public switched telephone network (PSTN) interfaces, and Internet connectivity.
Versatile connectivity
With support for Ethernet, Fast Ethernet, and Gigabit Ethernet, the Cisco 560 ensures high-speed connectivity for various network needs, making it a suitable choice for businesses looking to maintain robust, reliable connections. -
Comprehensive telephony support
The device's capability to interface with 4 phone (FXS) connections alongside VoIP support makes it a comprehensive solution for businesses seeking to integrate their telephony systems seamlessly with their network infrastructure. -
Expandable design
Featuring two expansion slots and support for CompactFlash Card, the Cisco 560 offers businesses the flexibility to enhance their system's capabilities as their needs evolve, ensuring a durable investment.
- Cisco Unified Communications 560 - VoIP gateway
- VoIP gateway
- Licence Qty
- 24 users
- Form Factor
- External - 2U
- Data Link Protocol
- Telephony Interfaces
- 4 phone (FXS), 4 line (FXO)
- Power
- AC 120/230 V (50/60 Hz)
- 44.5 cm x 35.6 cm x 8.9 cm
- 6.6 kg
- 1-year warranty
- VoIP gateway
- Height (Rack Units)
- 2U
- Installed Modules Qty (Max)
- 1 (2)
- 44.5 cm
- 35.6 cm
- 8.9 cm
- 6.6 kg
- Form Factor
- External
- Connectivity Technology
- Wired
- Line Rate
- T-1/E-1
- Line Coding Format
- AMI, B8ZS, HDB3
- Status Indicators
- Port status, system
IP Telephony
Communications
- Supported Flash Memory Cards
- CompactFlash Card
- Expansion Slots
- 2 (total) / 1 (free) x VIC
- 4 x FXO , 4 x modem - RJ-11 , 3 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x management - RJ-45 , 1 x audio , 1 x T1/E1
- Cables Included
- 1 x network cable , 1 x serial cable
- Rack Mounting Kit
- Included
- Power Device
- Internal power supply
- Voltage Required
- Limited warranty - 1 year
