Cisco UC 540 Base unit 8U Max 32Users 4FXO 8 PoE 1 VIC
Quicklinx: 6JH8WS00 Mfr#: UC540W-FXO-K9
The Cisco Unified Communications 540 of the Cisco Unified Communications 500 series for small business, is a critical part of the Cisco smart business communications system. It is an affordable unified communications appliance that provides voice, data, voicemail, automated attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, email, and customer relationship management (CRM) programs. This reference guide describes the specifications and capabilities of the Cisco Unified Communications 540 (UC 540).
Cisco Unified Communications 540 - VoIP gateway - Wi-Fi
VoIP gateway
Licence Qty
24 users
External - 1.5U
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Virtual interfaces (VLANs): 5 , VPN tunnels: 10
Telephony Interfaces
4 phone (FXS), 4 line (FXO)
Power Over Ethernet (PoE) Supported
PoE
26.7 cm x 28.1 cm x 6.7 cm
3.6 kg
VoIP gateway
Height (Rack Units)
1.5U
Installed Modules Qty (Max)
0 (1)
26.7 cm
28.1 cm
6.7 cm
3.6 kg
External
Wireless, wired
Switching Protocol
Ethernet
Status Indicators
Port status, system
IP Telephony
Voice Codecs
G.711, G.729a
Expansion Slots
1 (total) / 1 (free) x VIC
4 x modem - RJ-11 , 4 x modem - RJ-11 , 8 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x 100Base-TX - RJ-45 , 1 x audio , 1 x management - RJ-45
1 x network cable , 1 x serial cable
CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN50082-1, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, CS-03, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, EN 300 386
PoE
External power adapter
10 - 85%
