The Cisco Unified Communications 540 of the Cisco Unified Communications 500 series for small business, is a critical part of the Cisco smart business communications system. It is an affordable unified communications appliance that provides voice, data, voicemail, automated attendant, video, security, and wireless capabilities while integrating with existing desktop applications such as calendar, email, and customer relationship management (CRM) programs. This reference guide describes the specifications and capabilities of the Cisco Unified Communications 540 (UC 540).
- Cisco Unified Communications 540 - VoIP gateway - Wi-Fi
- VoIP gateway
- Licence Qty
- 24 users
- Form Factor
- External - 1.5U
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Capacity
- Virtual interfaces (VLANs): 5 , VPN tunnels: 10
- Telephony Interfaces
- 4 phone (FXS), 2 line (ISDN BRI)
- Power Over Ethernet (PoE) Supported
- PoE
- Power
- AC 120/230 V (50/60 Hz)
- 26.7 cm x 28.1 cm x 6.7 cm
- 3.6 kg
- VoIP gateway
- Height (Rack Units)
- 1.5U
- Installed Modules Qty (Max)
- 0 (1)
- 26.7 cm
- 28.1 cm
- 6.7 cm
- 3.6 kg
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Switching Protocol
- Ethernet
- Capacity
- Status Indicators
- Port status, system
IP Telephony
- Voice Codecs
- G.711, G.729a
- Expansion Slots
- 1 (total) / 1 (free) x VIC
- 2 x modem , 4 x modem - RJ-11 , 8 x 100Base-TX (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x 100Base-TX - RJ-45 , 1 x audio , 1 x management - RJ-45
- Cables Included
- 1 x network cable , 1 x serial cable
- CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, EN50082-1, AS/NZS 60950-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, CS-03, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, EN 300 386
- PoE
- Power Device
- External power adapter
- Voltage Required
- 0 °C
- 40 °C
- 10 - 85%
