Cisco Phone Adapter 1 x FXS, 1 x FXO
Quicklinx: 5DZ2WS00 Mfr#: SPA3102-UK
The SPA3102 features the ability to connect standard telephones and fax machines to IP-based data networks with the additional benefit of an integrated connection for legacy telephone network "hop-on, hop-off" applications. SPA3102 users will be able to leverage their broadband phone service more than ever by automatically routing local calls from mobile phones and land lines over to VoIP service providers and vice versa. If power is lost to the unit or Internet service is down, calls can be redirected to a traditional carrier via the FXO interface.
A user calling from a mobile phone or land line will be able to reduce and even eliminate international and long distance telephone charges by first calling their SPA3102 via a local telephone number. The advanced authentication and call routing intelligence programmed into the SPA3102 will route the call via the Internet to the far end destination. In addition, when using the SPA3102 at the far end, VoIP calls placed to that location can be either answered or further processed and routed on as a local call to any legacy land line or mobile phone.
The SPA3102 supports one RJ-11 POTS (Plain Old Telephone Service) FXS port to connect an existing analog phone or fax machine. The SPA3102 also supports one PSTN FXO port to connect to a Telco or PBX circuit. The SPA3102 includes 2 100BaseT RJ-45 Ethernet interfaces to connect to a home or office LAN, as well as an Ethernet connection to a broadband modem or router. The SPA3102 FXS and FXO lines can be independently configured via software controlled by the service provider or the end user.
Installed by the end user and remotely provisioned, configured and maintained by the service provider, each SPA3102 converts voice traffic into data packets for transmission over an IP network. Compact in design, the SPA3102 can be used in consumer and business VoIP service offerings. The SPA3102 uses international standards for voice and data networking for reliable voice and fax operation.
  • Toll Quality Voice and Carrier-Grade feature support
    The SPA3102 delivers clear, high-quality voice communication in diverse network conditions. Excellent voice quality in a demanding IP network is consistently achieved via the advanced implementation of standard voice coding algorithms. The SPA3102 is interoperable with common telephony equipment like voicemail, Fax, PBX, and interactive voice response systems.
  • Large-scale deployment and management
    The SPA3102 offers all the key features and capabilities which service providers can provide customized VoIP services to their subscribers. The SPA3102 can be remotely provisioned and supports dynamic, in-service software upgrades. A secure profile upload saves providers the time, expense, and hassle of managing and pre-configuring or re-configuring customer premise equipment (CPE) for deployment.
  • Ironclad security
    The SPA3102 supports secure, standard encryption-based methods for communication, provisioning and servicing.
Cisco Small Business Pro SPA3102 Voice Gateway with Router - VoIP gateway
VoIP gateway
External
United Kingdom
Ethernet, Fast Ethernet
VoIP Protocols
SIP v2
Telephony Interfaces
1 phone (FXS), 1 line (FXO)
10.1 cm x 10.1 cm x 2.8 cm
145 g
VoIP gateway
10.1 cm
10.1 cm
2.8 cm
145 g
United Kingdom
External
Wired
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, PPPoE
Remote Management Protocol
HTTP, HTTPS
Status Indicators
Port status, power
DMZ port, DHCP support, NAT support, Syslog support
IEEE 802.3
IP Telephony
VoIP Protocols
SIP v2
Voice Codecs
G.711, G.723.1, G.729a, G.726
IP Telephony Features
Echo cancellation (G.168)
1 x modem - RJ-11 , 1 x modem - RJ-11 , 1 x 100Base-TX - RJ-45 (WAN) , 1 x 100Base-TX - RJ-45
1 x network cable , 1 x phone cable
External power adapter
45 °C
10 - 90%
