Cisco IP Phone 7821 - VoIP
Quicklinx: C20PWS00 Mfr#: CP-7821-K9=
Deploy reliable and highly secure voice communications with the Cisco IP Phone 7821. This full-featured phone is easy to use and easy on your budget. This endpoint supports wideband audio for superior voice communications quality and advanced IP telephony features to make your business calls more efficient and productive.
  • TWO LINES
    Ideal for occasional-to-light voice communications needs of knowledge workers and managers
  • FIXED FUNCTION KEYS
    One-touch access to service, messaging, directory, hold/resume, transfer and conference features
  • FULLY PROGRAMMABLE
    Set up line keys to support either lines, such as directory numbers, or call features like speed dialling
  • OPTIMAL PERFORMANCE
    Class 1 PoE with 10/100BASE-T Ethernet connection through two RJ45 ports
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco IP Phone 7821 - VoIP phone
VoIP phone
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SRTP
Voice Codecs
G.722, G.729ab, G.711u, G.711a, iLBC
Lines Supported
2 lines
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - monochrome - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution
1-year warranty
VoIP phone
Body Material
PC/ABS
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Programmable Buttons Qty
2
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer
Additional Features
Music on hold
IP Telephony
Main Features
VoIP
VoIP Protocols
SIP, SRTP
Voice Codecs
Lines Supported
2 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
IP Address Assignment
DHCP, static
Security
IEEE 802.1X
Power Over Ethernet (PoE) Support
Network Protocols
Cisco Discovery Protocol (CDP), SRTP
Network Ports Qty
Compatible Software
Network Features
Lightweight Directory Access Protocol (LDAP)
Display
Display Location
Base
Diagonal Size
3.5"
Display Resolution
396 x 162 pixels
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Headset jack
Placing / Mounting
Wall-mountable, table-top
CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, FCC Part 68, EMC, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, VCCI Class B
Dimensions & Weight (Base)
20.6 cm
2.8 cm
20.7 cm
867 g
Limited warranty - replacement - 1 year
