Cisco ATA 187 WITH 600 OHM IMPEDANCE
Quicklinx: 779QWS00 Mfr#: ATA187-I1-A=
The Cisco ATA 187 Analog Telephone Adaptor is a handset-to-Ethernet adaptor that turns traditional telephone devices into IP devices. Customers can take advantage of many exciting IP telephony applications by connecting their analog devices to Cisco ATAs.
  • Enhanced call quality
    With features like echo cancellation, voice activity detection (VAD), and comfort noise generation (CNG), the Cisco ATA 187 ensures clear and uninterrupted voice communication, making every call as smooth as possible.
  • Versatile VoIP support
    Supporting a wide range of VoIP protocols including SIP and voice codecs such as G.711, G.729, and T.38, this device offers flexibility for various IP telephony deployments.
  • Robust networking capabilities
    Equipped with Ethernet and Fast Ethernet connectivity, along with features like DHCP support, Quality of Service (QoS), and VLAN support, the Cisco ATA 187 ensures reliable and efficient network performance.
  • Secure communication
    The device employs TLS encryption algorithm to secure voice communications, protecting against unauthorized access and ensuring privacy.
  • Easy management and compatibility
    This external VoIP phone adapter is designed for easy setup and management, featuring remote management via TFTP and compatibility with PC systems, simplifying integration into existing setups.
Cisco ATA 187 - VoIP phone adapter
VoIP phone adapter
External
Ethernet, Fast Ethernet
VoIP Protocols
SIP
Telephony Interfaces
2 phone (FXS)
AC 120/230 V
17 cm x 13.7 cm x 3.8 cm
260 g
VoIP phone adapter
17 cm
13.7 cm
3.8 cm
260 g
External
Wired
Framing Format
G.711
Network / Transport Protocol
TCP/IP, UDP/IP, ICMP/IP, DHCP
Remote Management Protocol
TFTP
Full duplex capability, dynamic IP address assignment, DHCP support, VLAN support, firmware upgradable, Quality of Service (QoS), static IP mode
Encryption Algorithm
TLS
IEEE 802.1Q
IP Telephony
VoIP Protocols
SIP
Voice Codecs
G.711, G.729, G.729a, G.729ab, G.711u, G.711a, T.38
2 phone (FXS)
IP Telephony Features
Echo cancellation, comfort noise generation (CNG), voice activity detection (VAD), call forwarding, Caller ID, call waiting, automatic fax/modem detection and pass-through
1 x 100Base-TX - RJ-45 , 2 x modem - RJ-11
MTBF
100,000 hours
RoHS, WEEE
External power adapter
AC 120/230 V
5 °C
45 °C
5 - 95%
