As this access point takes greater advantage of the multiple-input multiple-output (MIMO) features supported under the 802.11n standard, the number of radio transceivers per frequency band has increased. Using dual-band antenna port allows the access point to support these added transceivers while maintaining a reasonably low number of antenna connections.
OMNIDIRECTIONAL WI-FI ANTENNA
2 dBi (2.4 GHz)/4 dBi (5 GHz); white dipole (1 port); for use with Aironet 1830, 1850, 2800 and 3800 Series and Cisco Catalyst 9115AX, 9120AX and 9130AX Series access points -
CONNECTION AND MOUNT
RP-TNC connector -
360-DEGREE RADIATION PATTERN
Intended for deployment when coverage in all directions from the antenna is required -
PERFORMANCE
Designed for improved coverage -
PEACE OF MIND
1-year limited hardware warranty
- Cisco Aironet Dual-Band Dipole Antenna - antenna
- Product Type
- Antenna
- White
- Aerial Placing / Mounting
- Indoor
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- 2 dBi, 4 dBi
- Designed For
- Aironet 3602E
- Product Type
- Antenna
- Enclosure Colour
- White
Aerial
- Indoor
- Frequency Range
- 2.4 GHz, 5 GHz
- Gain
- 2 dBi, 4 dBi
- Designed For
- Cisco Aironet 3602E
