Cisco 250W Modular PSU
Quicklinx: BVRCWS00 Mfr#: PWR-C2-250WAC=
Type: Modules
£356.03 ex VAT
£427.23 inc VAT
The Cisco Catalyst Series Switches support dual redundant power supplies. The switch ships with one power supply by default, and the second power supply can be purchased at the time of ordering the switch or at a later time. If only one power supply is installed, it should always be in power supply bay 1. The switch also ships with three field-replaceable fans.
  • POWER
    250W AC power supply module; supports input voltages between 100 and 240 VAC
  • COMPATIBILITY
    For use with Cisco Catalyst 3650 series network switches
  • INTERNAL FAN
    Built-in fan for cooling power supply module
  • FLEXIBLE DEPLOYMENT
    Can be used alone or in combination with another AC power supply module
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco - power supply - 250 Watt
Power supply - plug-in module
Input Voltage
AC 100-240 V
Power Capacity
250 Watt
Pricing Type
Field Replaceable Unit (FRU)
Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Power Capacity
250 Watt
Cooling fan
Pricing Type
Cisco Catalyst 2960XR-24PD-I (250 Watt), 2960XR-24PS-I (250 Watt), 2960XR-24TD-I (250 Watt), 2960XR-24TS-I (250 Watt), 2960XR-48FPD-I (250 Watt), 2960XR-48FPS-I (250 Watt), 2960XR-48LPD-I (250 Watt), 2960XR-48LPS-I (250 Watt), 2960XR-48TD-I (250 Watt), 2960XR-48TS-I (250 Watt)
Type: Modules
Brand: Cisco
