Cisco 1000BASE-LX/LH SFP Transceiver
Quicklinx: 8TN0WS00 Mfr#: GLC-LH-SMD=
Type: Modules
Hurry, only 1 left in stock!
£460.42 ex VAT
£552.50 inc VAT
Express delivery Order within the next 24 minutes for delivery tomorrow
The industry-standard Cisco Small Form-Factor Pluggable (SFP) Gigabit interface converter is a hot-swappable input/output device that plugs into a Gigabit Ethernet port or slot, linking the port with the network.
  • COMPATIBILITY
    1000BASE-LX/LH SFP is designed for long-reach single-mode fibres but works over multi-mode fibre as well.
  • OPERATION
    Operates on standard single-mode fibre-optic link spans of up to 10 km and up to 550 metres on multi-mode fibre (transmitter should be coupled through a mode conditioning patch cable when used over multi-mode fibre type)
  • HOT SWAPPABLE
    Plugs into an Ethernet SFP port or slot with no need to shut down if installing or replacing
  • VERSATILITY
    SFP receiver/transceiver module supports 'pay-as-you-populate' model for flexible media and interface choice on a port-by-port basis
  • PEACE OF MIND
    5-year standard replacement warranty
Cisco - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC/PC single-mode
Plug-in module
Cabling Type
1000Base-LX, 1000Base-LH
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
1GbE
Max Transfer Distance
10 km
1.34 cm x 5.65 cm x 0.85 cm
75 g
1-year warranty
Cisco 38XX, 39XX, 39XX ES24, 4451, 8, 892; 250 Series; ASR 901, 901 10; Catalyst 29XX, 3560, 3650, 3750, 4500, 6900, ESS9300; Ethernet Services Plus Transport 20, 40; Industrial Ethernet 2000; Line Card E-Series; ME 3600, 3600X 24, 3800; Nexus 30XX, 7000, 7000 48; Supervisor Engine 7L, 8; UCS 62XX
Plug-in module
Wired
Cabling Type
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
1310 nm
10 km
Digital Optical Monitoring (DOM) support
IEEE 802.3z
1 x Ethernet 1000Base-LX/1000Base-LH - LC/PC single-mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
1.34 cm
5.65 cm
0.85 cm
75 g
Limited warranty - 1 year
-5 °C
85 °C
Cisco 3825, 3825 Branch Office in a Box Bundle, 3825 Secure WAN Optimization Bundle, 3825 SRST Voice Upgrades for HSEC Bundle, 3825 Unified Communications Bundle, 3825 Unified Communications Bundle with Advanced Security, 3825 WAN Application Acceleration Bundle, 3825 WAN Optimization Bundle, 3825C, 3845, 3845 Branch Office in a Box Bundle, 3845 Unified Communications Bundle with Advanced Security, 3845 WAN Application Acceleration Bundle, 3845 WAN Optimization Bundle, 3845C, 3925, 3925 Application Experience, 3925 Generation 2 STM-1 Bundle, 3925E, 3925E Application Experience, 3925E Generation 2 STM-1 Bundle, 3945, 3945 Application Experience, 3945 Generation 2 STM-1 Bundle, 3945E, 3945E Generation 2 STM-1 Bundle, 4451-X, 4451-X Application Experience, 4451-X Integrated Services Router, 4451-X Integrated Services Router Security Bundle, 4451-X Integrated Services Router Voice and Video Bundle, 4451-X Integrated Services Router Voice Security Bundle, 892 , Cisco 250 Series SG250X-48P , Cisco Catalyst 2960-Plus 24LC-L, 2960-Plus 24LC-S, 2960-Plus 24PC-L, 2960-Plus 24PC-S, 2960-Plus 24TC-L, 2960-Plus 24TC-S, 2960-Plus 48PST-L, 2960-Plus 48PST-S, 2960-Plus 48TC-L, 2960-Plus 48TC-S, 2960X-24PSQ-L, 2960XR-24PD-I, 2960XR-24TD-I, 2960XR-48FPS-I, 2960XR-48LPD-I, 2960XR-48TS-I, 3650-24PD-E, 3650-24PD-L, 3650-24PD-S, 3650-24PS-E, 3650-24PS-L, 3650-24PS-S, 3650-24TD-E, 3650-24TD-L, 3650-24TD-S, 3650-24TS-E, 3650-24TS-L, 3650-24TS-S, 3650-48FD-E, 3650-48FD-L, 3650-48FD-S, 3650-48FQ-E, 3650-48FQ-L, 3650-48FQ-S, 3650-48FS-E, 3650-48FS-L, 3650-48FS-S, 3650-48PD-E, 3650-48PD-L, 3650-48PD-S, 3650-48PQ-E, 3650-48PQ-L, 3650-48PQ-S, 3650-48PS-E, 3650-48PS-L, 3650-48PS-S, 3650-48TD-E, 3650-48TD-L, 3650-48TD-S, 3650-48TQ-E, 3650-48TQ-L, 3650-48TQ-S, 3650-48TS-E, 3650-48TS-L, 3650-48TS-S, ESS9300 Embedded Series , Cisco ME 3600X-24FS Ethernet Access Switch , Cisco Supervisor Engine 8-E, 8-E Redundant , Cisco UCS 6248UP Fabric Interconnect
Type: Modules
Brand: Cisco
