Chief Professional Mounting Lightweight Mobile Cart
Quicklinx: 76CGWS00 Mfr#: PFCUB
Accessory Type: Other
Hurry, only 1 left in stock!
£441.74 ex VAT
£530.08 inc VAT
A lightweight mobile cart is design with a collapsible, including telescoping height-adjustment and integrated cable management.
  • Effortless mobility
    Equipped with locking casters, this mobile cart allows for easy movement across different surfaces, ensuring your display is securely positioned wherever needed.
  • Versatile viewing
    Featuring adjustable height and Centris Technology, the cart provides optimal viewing angles for audiences, whether seated or standing.
  • Seamless setup
    Thanks to the Click Connect System, installation is simplified, allowing for quick and secure attachment of your flat panel display.
  • Comprehensive compatibility
    Supporting a wide range of display sizes from 55 to 100 inches and accommodating flat panel mount interfaces of 200 x 200 mm, this cart is designed for versatility and ease of use.
  • Integrated organization
    With integrated cable management, the cart keeps cables neatly organized, ensuring a clean and professional appearance for your AV setup.
Chief Large Height Adjustable Mobile Cart - For Displays 55-100" - Black stand - for flat panel - black
Stand
Mounting Components
Interface bracket
94.3 cm x 81.6 cm x 207.3 cm
Recommended Use
Flat panel
Recommended Display Size
42"-71"
VESA Mounting Interface
200 x 200 mm
Max Mounting Pattern Size
862 x 517 mm
Max Load Weight
90.7 kg
94.3 cm
81.6 cm
207.3 cm
AV Furniture
Stand
Mounting Components
Interface bracket
Recommended Use
Flat panel
200 x 200 mm
862 x 517 mm
Cable Management
Integrated cable management
42"-71"
Max Load Weight
90.7 kg
Adjustable height, locking casters, Centris Technology, Click Connect System
Brand: Chief Professional Mounting
