Canon i-SENSYS MF832Cdw Colour Laser Multifunction Printer
Quicklinx: G7F9WS00 Mfr#: 4930C011AA
Functionality: Printer, Copier, Fax, Scanner
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Laser
£686.98 ex VAT
£824.37 inc VAT
Print, copy, scan and fax faster than ever before, with an all-in-one color laser printer optimized for seamless working, whether in or out of the office. Fast and flexible working with enhanced collaboration boosts productivity, wherever you are. Move securely between working environments with customized controls, advanced connectivity and an intuitive user experience.
  • Optimized productivity
    Streamline process efficiency, with rapid print and scan speeds, small media support and centralized print management through Microsoft Universal Print.
  • Intuitive user experience
    Expert user control is easy thanks to natural workflows and one-touch commands on the large 17.8cm/7-inch LCD touchscreen display.
  • Enhanced connectivity
    Stay connected for the ultimate collaboration and productivity, with mobile apps and dual network capability.
Canon i-SENSYS MF832Cdw - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 38 ppm (mono) / up to 38 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
1200 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Scanning
600 x 600 dpi
Display
7"
Original Size
48 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
100 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, coated paper, heavy-weight paper, thin paper, postcards, coloured paper, prepunched paper
Standard Media Capacity
650 sheets
Max Media Capacity
2300 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
200 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud, wireless direct printing, scan to FTP, Push Scan, Pull Scan, scan to PC, iFAX
AC 230 V (50/60Hz)
50 cm x 55.6 cm x 64 cm
41 kg
2-year warranty (France - 3 years with product registration)
Printer Fonts
PCL x 93 , PostScript x 136
Fax Type
Plain paper
Printing Technology
Laser - colour
80000 pages
2000 pages
Display Diagonal Size
7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
2 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
Toner Save, ID Card Copy, Preset Reduction/Enlargement Ratios, Sort, Frame Erase Copy, Job Build, blank page skipping, adjustable copy density, N-in-1, interrupt mode
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c, PDF, TIFF, XPS, UFRII, JPEG
Automatic Duplexing
Scanning
Optical Resolution
600 x 600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 30000 pages
PC Faxing
Yes (send only)
Fax Machine Features
Speed Dialing
200 station(s)
Telephone / Fax Switch
Broadcast Transmission
256 stations
Delayed sending, fax preview
Document & Media Handling
Min Original Size
48 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 48 x 128 mm
Original Type
Sheets
100 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 297 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), 101.6 x 148 mm, Foolscap
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
650 sheets
Max Media Capacity
2300 sheets
100 sheets
200 sheets
ADF - 100 sheets size: 48 x 128 mm - Legal (216 x 356 mm) weight: 42 g/m² - 128 g/m² , Paper cassette - 550 sheets size: 101.6 x 148 mm - 216 x 297 mm weight: 60 g/m² - 163 g/m² , Multi-purpose tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 200 sheets
Speed Details
Printing: up to 38 ppm (A4) - colour , Printing: up to 38 ppm (A4) - B/W , Printing: up to 59 ppm (A5) - colour , Printing: up to 59 ppm (A5) - B/W , Copying: up to 38 ppm (A4) - B/W , Copying: up to 38 ppm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, TLS, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, Wi-Fi Direct, SNMP 3
Operating System Support
MS Windows Server 2012, Windows 8.1, MS Windows Server 2012 R2, Windows 10, MS Windows Server 2016, Apple Mac OS X 10.11 or later, MS Windows Server 2019
Software Included
Drivers & Utilities, iW Enterprise Management Console
AC 230 V (50/60Hz)
1500 Watt
Power Consumption Standby
33.3 Watt
Power Consumption Sleep
1.1 Watt
Warm-Up Time
12 sec
Consumables Included
1 x toner cartridge (black) - up to 6000 pages - Canon 064 Starter , 1 x toner cartridge (cyan) - up to 3200 pages - Canon 064 Starter , 1 x toner cartridge (magenta) - up to 3200 pages - Canon 064 Starter , 1 x toner cartridge (yellow) - up to 3200 pages - Canon 064 Starter
Regional Warranty Exceptions
50 cm
55.6 cm
64 cm
41 kg
10 °C
30 °C
20 - 80% (non-condensing)
Functionality: Copier
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: Canon
Price Range Ex VAT: £500 - £750
