Enjoy this connected 4-in-1 mono laser printer, built to deliver everything, a small office needs: print, copy, scan and fax from PCs, smartphones and tablets.
An ideal office companion
If you run a small business or work from a home office, you’ll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax.
Monitor from a PC or mobile
Access printer information, change network settings, set up the address book and check toner levels – all from the Remote User Interface (RUI).
Sustainability matters
The printer’s ECO reports make it easy to monitor and track usage, while Auto Off and reduced power consumption modes help keep your carbon footprint to a minimum.
If you run a small business or work from a home office, you'll appreciate the fast, reliable mono print quality, touchscreen display and print, copy, scan and fax. -
Access printer information, change network settings, set up the address book and check toner levels - all from the remote user interface (RUI). -
The printer's eco reports make it easy to monitor and track usage, while auto off and reduced power consumption modes help keep your carbon footprint to a minimum.
- Canon i-SENSYS MF237w - B/W
- Printing Technology
- Laser (monochrome)
- Original Type
- Sheets
- Media Type
- Envelopes, plain paper, labels
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- AirPrint Enabled
- Power
- AC 230 V
- 2 Years
- Laser - monochrome
- AirPrint Enabled
Copying
- Grayscale Half-Tones
- 256
- Max Document Reduction
- 25%
Printing
Scanning
- Colour Depth
- 24-bit
Document & Media Handling
- Original Type
- Sheets
- Supported Media Type
- Voltage Required
- AC 230 V
- 30 °C
- 2 Years
Canon CRG-737 Black Toner Cartridge | In Stock | £59.60 |
