RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
RapidRun Multi-Format represents the most significant upgrade to the RapidRun cabling solution to date. With enhanced engineering that includes individually shielded pairs and an isolated ground for audio lines, this runner cable meets the rigorous demand for applications in which multiple audio/video devices are run over a single cable.
Use this CMG-rated Multi-Format runner for in-wall installations that support high-density, multi-format applications. Whether hanging a projector in a modern 21st century classroom or installing a commercial digital signage system, a clean, crisp signal will be delivered every time.
- C2G RapidRun Multi-Format Runner Cable - CMG-rated - video / audio cable - 7.6 m
- Cable
- Video / audio cable
- Length
- 7.6 m
- Black
- Connector
- MUVI connector - female
- Connector (Second End)
- Colour-coded connectors, in wall mounting
- Limited lifetime warranty
- Cable Type
- Length
- 7.6 m
- Black
- Connector
- Limited warranty - lifetime
