C2G Mini HDMI to DVI Adapter Dongle
Quicklinx: D0BTWS00 Mfr#: 80505
Length: 20.3cm
£6.34 ex VAT
£7.60 inc VAT
This HDMI Mini to Single Link DVI-D Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI Mini-enabled Chromebook, laptop or other source device to the DVI-D input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1200. Simply connect the adapter directly to the output port of a Chromebook or laptop and use a standard DVI-D cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Colour
  • Resolution
    Up to a 1920x1200 video resolution is supported
C2G HDMI Mini to Single Link DVI-D Adapter Converter Dongle - adapter - HDMI / DVI - 20.3 cm
Cable
Adapter - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
32
TMDS Links
Single link
Length
20.3 cm
Connector
DVI-D - female
Connector (Second End)
19 pin mini HDMI Type C - male
Cable Type
Adapter
Interface Supported
HDMI / DVI
Double shielded
32
TMDS Links
Single link
Jacket Material
PVC
Shielding Material
Length
20.3 cm
Connector
18+1 pin digital DVI (Single-Link) - female
Limited warranty - lifetime
Length: 20.3cm
Brand: C2G
