C2G HDMI to Single Link DVI-D Adapter Converter Dongle - Vid
Quicklinx: BWJ6WS00 Mfr#: 80502
Length: 20.3cm
£7.32 ex VAT
£8.78 inc VAT
This adapter converter dongle is an ideal solution for connecting the video output of a HDMI-enabled laptop to a DVI-D display. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter. Up to a 1920x1200 video resolution is supported, allowing this adapter converter to meet the needs of a high performance application. Connect this adapter directly to the output of a laptop and use a DVI-D cable to connect to a display.
  • Colour
  • Resolution
  • Warranty
    Lifetime
C2G HDMI to Single Link DVI-D Adapter Converter Dongle - adapter - HDMI / DVI - 20.3 cm
Cable
Adapter - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
32
TMDS Links
Single link
Length
20.3 cm
Connector
DVI-D - female
Connector (Second End)
HDMI - male
Cable Type
Adapter
Interface Supported
HDMI / DVI
Double shielded
32
TMDS Links
Single link
Jacket Material
PVC
Shielding Material
Length
20.3 cm
Connector
18+1 pin digital DVI (Single-Link) - female
19 pin HDMI Type A - male
Limited warranty - lifetime
Length: 20.3cm
Brand: C2G
