C2G Centronics 50 M/M Gender Changer (Coupler)
Quicklinx: 685HWS00 Mfr#: 81509
Centronics gender changers from C2G easily let you change the gender of a 50-pin connectors. With these changers, you will be able to use your existing centronics cables by altering the port connection on your device or cable. In addition, they can be used to splice together two existing cables.
C2G SCSI external gender converter
Shielded
EMI/RFI protection
Connector
50 PIN Centronics - male
Connector (Second End)
Beige
Storage Cable Type
Shielded
EMI/RFI protection
Beige
22.2 g
Connector
