C2G 7m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BPYWS00 Mfr#: 83391
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience fast data transfer speeds with the Cat6 Booted Unshielded (UTP) Network Patch Cable, tested up to 550 MHz. This ensures efficient handling of high-speed data for applications such as streaming, gaming, and large file transfers.
  • Durable design
    Constructed with 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is designed for durability and long-term use. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring a consistent and quality connection over time.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable features RJ-45 male connectors on both ends, making it versatile for connecting a wide range of devices in your network setup.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
24
Plated Connector
Gold
Length
7 m
Blue
Connector
RJ-45 - male
RJ-45 - male
Up to 550 MHz
